San Bartolome kit No. 00132 Build.
I also had the same problem and had to put extensions. But it will not be the only time that you will have to improvise and use leftover wood, so I recommend that you do not throw anything away until you are finished.
Many thanks Otsoa.
Hull planked now both sides. Still finishing to do but found this bit really hard.
The pre cut planks were ok counting down from 15 to 7, but as soon as I got after this, they just fitted terrible. So much sanding to make them lie properly.
Still don’t really understand why as other builders say they lay quite well without too much work. Must be me.
Got there in the end but hated this part of the kit.
Few pics !!!
Also cut out better access in the slipway for the keel brackets as that got a bit fiddly trying to get the screws in. Slip way still solid as a rock and hasn’t interfered with the integrity of the base.
One for Pavel to ponder at I think.
Few pics !!!
Looks fantastic Neil, got a lovely finish to it
Been busy doing a few more bits.
Some of Pavel’s precut pieces are over cut , I think less would have been better as you have to rectify the mistakes. But generally not too bad.
Just laid some of the pieces on the ship to see how it will all come together.
All ready for patina and weathering.
Nothing glued as yet, so the joints should come out even better once clamped.
More finishing touches to the decks. Dyes working a treat. Don’t think Pavel’s painting kit will see through the build, nearly out of oak dye already but will see if I can match it with a more local Uk supplier. Don’t know if it’s classed as light, medium or dark oak. Will do a few tests and keep you posted.
