San Felipe 1690 from ZHL
Time for a big update.
  • Planking and sanding of the cherry and the mahogany completed.
  • Staining the mahogany completed. But..... Not happy.
  • Phase one of decking the lower deck completed. Next phase is to do the tree nailing
  • Started the task of glueing the interior planks.
After sanding the daylights out of the cherry and mahogany I was very pleased. Only a couple of thin gaps that needed to be filled. Beveling worked out great and I still cannot say enough about the clamps. So, it's time to stain the bottom whilst the top is still basically empty of detail. Blue tape and the stain was "Red Mahogany". Even after using my fingernail and pressing the tape down very hard it still blead into the cherry. ARG. Next!! The stain looks more like walnut then mahogany. I'm going to sand it off and use something different. My concern is those softer mahogany planks soaking in the wood too far to sand off. If that is the case I'll be stuck with this darker stain. We'll see.
View attachment 408265View attachment 408266
Mahogany comes in different colors from light to dark. The stain you used resulted in a dark finish, but there is still a hint of red, and the grain is still indicative of mahogany. On dark woods like mahogany and American walnut, I like to used oil such as Danish Oil instead of stain so it doesn't get too dark. Danish Oil has some stain in it, but you can choose to use the Light Walnut Danish Oil to keep the color lighter. I know you wanted a lighter finish, but I think your hull still looks good!
Time for some sort of post. Been pecking away at the frame. Dealing with a few parts that are flat out labeled incorrectly. I am to the point now where I won't glue on a part until completely convinced myself that it actually goes there. I guess that is all part of the fun.
Tree nailing is a whole lot more difficult than it looks. The only smart thing I did here was attempt this on a section of the boat that is under a deck. Learned a couple things here. Do a deep mark where you want to drill the hole. The Dremel will jump on you. I ended up with plenty of holes in the wrong spot. Another thing is to stain the tooth pics first. With this pear veneer you can barely see them. Once I get the entire deck finished, I'll make a decision on whether or not to stain.
I have some correcting to do on the very back of the boat. Once done with that I'll start planking.
Greg. On the back of the boat the drawings call for part 48 (wrong) it's part 47 that you want.
Have a nice day everyone.
View attachment 396656View attachment 396657View attachment 396658View attachment 396659
After modifying the cannon holders I went ahead and started some planking. The planks I made are plenty thick and very stiff. I figure I'll be able to do three per evening. So it's going to be a slog. Going to take my time because I want to get it right. I'll start with the Cherry.
Scott, How did you know where to begin your planking?
Oops, you're correct
Hi,
Maybe you can use "Snipping tool". That is what I use to make an image of a Youtube in pause mode. With your mouse you can make a select square and save it as .jpg. Where you want it.
Than run the video and stop it where you want. And "snip" again.
Put in your search engine "snipping tool download" and this is a free download from different locations.
Goog luck. ;)
Hi,
Goog luck. ;)
Thank you.
Thoroughly studied the plans last night.
Found one side detail that gives a hint.
Did a myocardial perfusion test at the doctors this morning. It feels like you're having a heart attack for about thirty seconds. Needless to say I was drained for the remainder of the day. So I spent the day planning.
Their are two bulkheads made with vertical planks and containing two doors
Both are recessed with overhanging decks above. I'm planning on building these next while I have access.
The same goes for the deck planking going back under the overhangs. Easier access now. I hope it doesn't get banged up during the build.
In home construction we would often place cardboard taped securely together to protect finished floors during construction. I wonder if that might be a help on this model.
Happy modeling
