Terry,enjoying the build. Your correct on the price of the kit. I may have to give it a try.
Thank you for your comment.
Jeff
Terry, do you have a build log yet?Gun rigging looks good. looks like fun to me.
I wish I had thought of taping shut my lower decks to keep out the sawdust and detritus on my Black Pearl. Ingenious. I also wish I could find a way to simulate tiny blocks for my upper deck guns.Deck supports are in. It was a lot easier to install them before the false deck above was installed since you can reach from above and not just from the side. In retrospect it would be best to do the same on the lower deck. I also installed the upper false deck. Planking the of the upper deck is next followed by two layers of planking of the inner bulkheads.View attachment 193950View attachment 193949
looking really good! I wish I would have payed more attention to your build. I followed the sequence in the plans.Now I have to populate the lower decks with the upper decks installedThe main deck planking is installed. Using the 0.5mm strips supplied with the kit makes this go very easy along with the completely straight deck.
The next step was to line the bulwarks with the first layer of planking and cut out the gunports.
View attachment 194510View attachment 194511
I delayed cutting in the scuppers until I had the underlying planking on the bulwarks. This was a step that I have been concerned about. In the end I drilled 4 holes in a line for each scupper and using a #11 blade and a flat file I cut them in. I am happy with the way they turned out.
Note to other builders: Don't place the gunport frames on the outside of the ship until the planking of the bulwarks is completed.
A bit of paint on the insides of the gunports and scuppers.
The final planking on the bulwarks completed with the curve to the bulwarks sanded even. I then sanded the bulwarks and clear-coated them.
Progress to date. Next steps - The capstans or the deck grating.
View attachment 194515View attachment 194516
I am not certain how I would have rigged the middle deck guns if I would have installed the upper deck first. I guess the guns could be fully rigged and then you would just have to put the eyebolts in place. My eyes are not good enough to have seen the holes in the shadows. I suggest doing the innermost guns first.looking really good! I wish I would have payed more attention to your build. I followed the sequence in the plans.Now I have to populate the lower decks with the upper decks installedIt will be a challenge.
