Santisima Trinidad Occre 1/90 scale
Good evening all, here a small update of my Santisima Trinidad, as you can see I am a bit busy with all the little things on the deck and the hull (I'm just someone who can not spend hours on a thing, I like variety, some will think that this is not the way but yes I am too old to change jjijijijijijiji and it goes also like this)
the little samsons on the limberboard I have changed to 3x because I was not happy with the work done, now I've found more or less how it should be but is still amenable to improvement. Do not stay distant, and give critic as the work for improvement is possible
greetings from Ostend
willy
IMG_20180516_175908.jpgIMG_20180517_151042.jpgIMG_20180518_180246.jpgIMG_20180518_180328.jpgIMG_20180519_143832.jpgIMG_20180519_143841.jpgIMG_20180521_174747.jpgIMG_20180523_160213.jpgIMG_20180523_171409.jpgIMG_20180523_175930.jpg​
Wow....you made great progress on her. It is looking very good.
thanks to all the colegas for your comment and like's.
So finally the first row of cannons is ready, and I have already seen a few problems, namely that I do not have enough space to put the stairs to the top deck properly but every problem has its solution.
I used 80 blocks for the first row of cannons and fifty eyespins
Greetings
willy
IMG_20180529_161917.jpgIMG_20180529_161942.jpg​
Looks like a lot of work for my ship too. Great Job. How is Your wood quality? I have a lot of damaged wood. Espescialy the wood for the decks.
That must have been a hell of a work. How has it taken to rig the cannons?
232/5000
Good morning Wolfgang, sometimes I was close to the red point jajajajaja, but generally it went well, a problem was the block with their small holes, and the strings that did not always want to go in the holes
greetings from Oostende
Willy
Is there no hidden bag somewhere in the kit. Everything was in plastic boxes and they where sealed with tape
hello all
this afternoon i have done a bit of finishing on the upper deck, and also the stairs to the Quarter deck in place (did not have enough space to get him in there but have made a small change to the finish of the quarter deck and now is it right) with just a bit of finishing to do between the stairs and it is done
Greetings from Oostende
willy
IMG_20180531_155348.jpgIMG_20180531_180024.jpgIMG_20180531_180103.jpgIMG_20180531_180049.jpgIMG_20180531_180155.jpg​
