- Dec 7, 2022
As usual, I am coming in late. just going through your bild from the start today. just for your information, I started this hobby in the early 1960s with Billings Boat KIT. I was brought up in Northern Denmark in a total fishing family. Had 6 uncles, each one with their cutter At that time there was not much help- information, tools etc., as it was just the beginning- O can remember have many it went to the Bin. Finally, I got it, as you may have seen, the hulls are all alike. The differences from one cutter to another were mainly the Wheelhouse, the fishing tools, and the lifeboat- which is changed to a cilender with a gummi Boat inside and you have on yours. to make a Long story short, once you have built the Hull, you can change each into another according to the type of catch- trawling, with hooks etc.I wish you success and a lot of fun with this kit - we will follow your work with big interest
Hi, as you can see -aparte from the seizure -the Hull followed the same rules. They were all built in Denmark by local Shipbuilders, after some rules. In general, the were 3 seises= 15 tons -the smallest like Havmaagen; then the 20-ton cutter (the biggest amount) an finally 30 ton like Mary Ann,As usual, I am coming in late. just going through your bild from the start today. just for your information, I started this hobby in the early 1960s with Billings Boat KIT. I was brought up in Northern Denmark in a total fishing family. Had 6 uncles, each one with their cutter At that time there was not much help- information, tools etc., as it was just the beginning- O can remember have many it went to the Bin. Finally, I got it, as you may have seen, the hulls are all alike. The differences from one cutter to another were mainly the Wheelhouse, the fishing tools, and the lifeboat- which is changed to a cilender with a gummi Boat inside and you have on yours. to make a Long story short, once you have built the Hull, you can change each into another according to the type of catch- trawling, with hooks etc.
YOUR HULL LOOKS PERFECT
ADD for info. I will add some of these cuttersView attachment 406944View attachment 406945View attachment 406945View attachment 406944
hi Uwe, the images I sent out are not from Panteg Models, but are a finished build model, but Panteg is doing well. The main problem is the Wheelhouse -here you can radar and other electronic equipment -not in the instruction book. I have over 100 images of these cutters.Very good work - you are on a very good way
My comment was not related to your post - everytime to the author of the building loghi Uwe, the images I sent out are not from Panteg Models, but are a finished build model, but Panteg is doing well. The main problem is the Wheelhouse -here you can radar and other electronic equipment -not in the instruction book. I have over 100 images of these cutters.
THE IMAGES I SEND ARE NOT FROM A S,O.S. MEMBERMy comment was not related to your post - everytime to the author of the building log
I know that the above-inserted images are not in the right place. I only wanted to show the actual builder of this boat, a finished boat as a help. sorry Uwe. delete them if you wish.THE IMAGES I SEND ARE NOT FROM A S,O.S. MEMBER
Thanks the completed Boat images do help .I know that the above-inserted images are not in the right place. I only wanted to show the actual builder of this boat, a finished boat as a help. sorry Uwe. delete them if you wish.
It is very well built, as I remember 60 years ago or more, just it -no critic - a little too clean. These boats a cutter were generally very dirty with oxidation, crashed ?? (dirty) hulls etc. Only when they had to go to the yearly ITV. very well done.Just a little more progress , cabin glued in place and a little deck furniture added . Failed to get the name decal to detach from the backing paper
so will need to make a name plate of my own.
A lovely little boat. AwesomeJust a little more progress , cabin glued in place and a little deck furniture added . Failed to get the name decal to detach from the backing paper
