Just WOW, especially jour painting! Great work, Ken.Hello, again thanks for your likes. Today’s update is showing you the completed rigging, the mounted engine, a few bits and bobs and the very nice display stand. The rigging was a real pain to do, the eyelets being stainless steel PE have very sharp internal edges, the thread could only be pulled through if it was vertical to the eyelet and not at even a slight angle otherwise the sharp edges gripped and prevented the thread from sliding through, it was therefore very difficult to get any tension whilst tying off. Another issue was the eyelets only had a small contact area on the wooden frames and easily came away when tension was applied, some pieces even had three eyelets attached to one small piece of PE making things even more precarious, all pretty frustrating, but with a bit of ingenuity I prevailed. I started to make up the undercarriage, but I broke one of the two axles, I wasn’t worried as I have found that the replacement service to be excellent so I requested a new one. In the meantime I started to make up the second axle unit, knowing how brittle the first had been I was very careful, unfortunately I broke that one as well in exactly the same place so I’ve decided to make my own axles. I think that a couple of days at the bench will see this project finished and I’ll be moving on to my next one.
