- Jun 29, 2024
Thanks for explaining it guys. Looking at the pictures, particularly that of the Great Admiral, I understand what you are saying.
Roger
Roger
Can’t wait. I want to see the skylight,, passage way and binnacle fit next to the wheel and steering box.Rob,
Considering the tiny size of a 1:96th scale structure, I think you did an excellent job, as usual. I was merely pointing out that my delayed conceptual sketch didn't match your brilliant work.
By the way, relocating ship's wheel housing and correcting companion size, a 13' large skylight does fit. I'm about 90% done on the entire 44' poop deck and expect to be done tomorrow.
No problem Roger. Glad we helped.Thanks for explaining it guys. Looking at the pictures, particularly that of the Great Admiral, I understand what you are saying.
Roger
Well, I figured it was about time to begin my Staghound build log. The bulkheads are finalizing and are in route soon. That subject will come up for sure...but much has been done off line privately...to save a lot of haggling and recreating Staghounds dimensions. I have several partners who aided me in the research of my last build Glory of the Seas....they, again have come to my aid again and will input most of the particulars of the design and what we have been up to for the last months.
While I waited for the production of the bulkheads...I wanted to work on many items that would take time, during the lull.
First...here is a painting of the Clipper I am going to build....she is Donald McKay's first clipper. His entry into the fast paced world of the ever changing clipper design.
Staghound was an extreme clipper, one that the owners gave Donald McKay full charge of. He designed her, decided on her particulars, and had full card blanch' in her construction.
I will attempt to do her justice.
Firs I began with her namesake...the Staghound figurehead. She is 7/8 long.
Carving up the figurehead.
Guilded Gold
Rob
Me and my talented researchers and CAD programers , developed our own from Donald McKay’s own floor lofted model, made by his son.I think you're the best I have ever seen. I would like to see other product from you. Where did you get the plans for the 1/96th Staghound?
Yours truly
David Altbaum
Rob,Rich……I’m liking the first option. 2.5 ft from skylight to portico stairs is, IMV too tight a working space for the crew. 10ft still meets the requirement of , “a large” skylight, when a 6ft one was typical.
That stove pipe must have been nearly right at the foot of the stair of the companion way stairwell in the main large cabin, if it was one ft forward of the companion way house on deck.
Rob
David's Boats:I think you're the best I have ever seen. I would like to see other product from you. Where did you get the plans for the 1/96th Staghound?
Yours truly
David Altbaum
Rob,Rob,
I agree entirely. 13' is just overkill. I also like the balance of the skylight being closer to center as well. I will revise my deck plan to reflect a 10' skylight.
Well I’ll be……….10ft just felt right.
You will have a drawing done with all the spacing and items laid out on deck …..right? That will be a main item I’ll use to set the deck furniture and the deck prisms.
Rob
RobWell I’ll be……….10ft just felt right.
Rob
Rob,Fantastic. I’ll copy this and write in the specific dimensions for each item.
This will also aid in installing the external hull port holes for each outboard cabin.
Thanks Rich
Rob
Did you do all the drilling & tapping, or were they purchased?I again....took the time to make items for the ship that didn't require the hull....so I next made the many stanchions needed for the fantail, poopdeck rail and the small portico. These stanchions are quite small. The outer rail stanchions are a scale 10"....less that an 1/8".
I first had to tool up on my mini mill the railing itself and drill the stanchion seats.
Stuart Little:Did you do all the drilling & tapping, or were they purchased?
