Just put it up in build logs as a independent build log. Doesn't matter that you're putting it all up at once.Yes will do Tony P once I’ve finished the rigging. Should be by Xmas. Not sure where you can post the finished build AND the photos of the build log?
Yes. Did you order it yet ? I have beech I can use here for the keel assembly. The thinner frame and ceiling lumber I have to get still.Hello Tony,
I'm planning to use a combination of cherry and beech. Like you, I may use beech throughout the build.
Bill
Oh ok thanks yes. I’ve seen it. Didn’t know that was you there. Just curious as it doesn’t seem clear to me.Tony P
I can’t remember exactly what I did now.
However I remember asking the same question on another forum and got this reply:
Quote: Hi Clogger I followed line “e” on the plans. The line is only drawn on the starboard side of the plan and is not reflected on the port side. To solve this I ran a centre line down some tracing paper and traced the starboard side. I then flipped the paper over to get the sameprofile on the port side.
Good morning Denni, the observation that with regard to what you say, in the past I had exposed them on some construction sites but, I only received negative responses from various opinions. FrankBeing very new to reading and understanding plans, this is the first thing I noticed that (to me) I could make a mistake. Below are shown how the Floor Timbers reverse directions at the midpoint of the Keel or thereabouts. Also, I found out the mystery of those tiny circles and arcs on Planche 4.
Page 19 in the LeR booklet.
Planche 4
(note: the tiny circles w the arcs are spacers/chocks
between the frames for the passage of water).
Planche 2
Very good idea - I am pretty sure, that there is a need for such parts....Ahoy!
If anyone needs anchors and decors for the model LE ROCHEFORT..... WELCOME
View attachment 345978View attachment 346400
