The Schooner Bluenose 1921, POF Yuanqing Models 1:72
Thanks Mark, what's interesting to me is I have yet to use any CA glue, it's all PVA at this point and it gives me time to apply and spread it then position it and clamp.
Totally agree. Using CA always seems to add an extra layer of stress to the process - you know you only have pretty much one shot at it and very little time to do it in!
While waiting on my deck boards delivery I permanently placed the water boards. I will have some patch and repair in a few locations, but I will wait till I cut the ship out of its framing jig first.
I decided to begin application of the bulwarks while still in the jig as it provides a good stable base on its side.
View attachment 377088View attachment 377089
Perfect position for bulwark installs. By the way aligning the bottom of the drain scuppers with the top of the water boards give the corect elevation placement. From there you just have to endo with (in my case) the best average location as close to the plans as possible.
Hope you all enjoy. Happy modeling!
For sure I enjoy! Looking very nice, Daniel. Some toothpicks through the scuppers can be helpful by the alignment.
I remember using square stock that was long enough to go through both sides, and taped it to the top of the waterway boards in about 4 places per deck. That established the height and the location bow to stern. I used the deck beams as a guide for alignment bow to stern.
Makes sense…work smart, not hard! ;)
I've seen men and women becoming a millionair combining both. :cool:
Wow look at the progres you made and the beauty. Congrats on the results so far Daniel. A truely nice and detailed log to follow. Clean and crisp work. With your log you will guide new builders of BN in the near future..
Good morning, everyone.
A little bit of progress and a possibly a better mouse trap. I began placing the hull planking and decided that leaving the jig frame in place provides the best stable platform for this operation. Once completed I will remove it. I use my trusty plank bender (womans hair curler) which works really well. Just dip the end in water a minute or two then heat and bend.
I tried several methods to hold some of the more argumentative planks fast to the frames and came up with this. It works great! Take a simple paperclip bend it as shown, insert between the ribs and turn it 90 deg then wedge it in place.
Hope you enjoy, and happy modeling.
View attachment 377462View attachment 377463
View attachment 377464View attachment 377465
Clever!
Thank you for your kind words, Peter.
Smart solution!
G
Good evening Daniel. “Good thinking Batman”. Those first set of planks are so good. It must be really rewarding working with good wood. Cheers Grant
Nice idea about the bended paperclips, Daniel. About the positioning of the planks, (and perhaps you already know): because of the laser cut, they have a slight chamfer on the sides: /___\. When you put 2 of them side by side /___\/___\ then you get a tight connection with almost no gap between the planks. Especially when you get to the curve of the frames.
Thanks Peter, I'm aware of the laser chamfer and it does provide a good tight match up and in some of the curvier locations I even file a more angled chamfer to help with a tight fit.
Putting them on the other way around is clearly visible. Paying a little attention during dry fit is very helpful.
The end result is worth your while.
I see what your seeing Johan, toward the bow what must appear as an open v joint is in reality a slightly horizontal offset which I hope will sand out smoothly prior to painting. Now at the stern section I may need some hairline fillers where there is a change in direction. Either way I will be painting the pearwood because I really like the red black (maybe dark blue) combo color.
You're gonna paint both port- and starboard sides?
Yes, however the starboard side only has 5 boards including the bulwarks. At least that's my plan for now, I may change my mind once I sand out the pearwood and get a good look at a more complete picture.
Regardless what you choose, one side will remain open, showing the beauty of the frames.
Personally I was impressed by the effect a stained port side had on the appearance.
In the end it boils down to ones personal preferences...
