Titanic Trumpeter 1/200 [COMPLETED BUILD]
That really is an incredible build, well done! I have a question (for you and anyone else who has inout)... what do you do for the rigging to ensure it stays taught and does not sag with time, temperature and environment? Anyone have advice?
Roger,
BEAUTIFUL work - She looks awesome. Deck benches are also perfectly scaled as well.....
One very minor question - I'm not too versed on naval history - why the American flag at the top of one of the masts?
PS: My Admiral and I are going to Mexico next week (Guadalajara) for a friend's son's wedding. Our son will also meet us there,but he will
visit DF for a few days before.
Love Mexico - lived in DF for two years (Colonia Polanco) when I was a young teenager.
Saludos
Hola Roger. Has construido un Titanic magnífico. Una duda, es tal como viene el kit o has utilizado algún pack de mejora? Tengo la duda si comprarme el de Amati o este de Trumpeter.
Hello Roger. You have built a magnificent Titanic. One question, is it as the kit comes or has it used an improvement pack. I have a doubt without buying the one from Amati or this one from Trumpeter.
Se que uno es de madera y el otro de plástico y de escalas diferentes. Pero este de Trumpeter es muy bueno en el detalle.
I know that one is made of wood and the other is made of plastic and of different scales. But this one from Trumpeter is very good at detail.
Saludos ;)
Hola! el tal cual el kit usando nada mas las cubiertas de madera de Scaledecks. Volvi a armar el modelo esta vez usando el kit Pontos..no he subido fotos. Yo sugiero que armes el Trumpeter ya que es el mas detallado
Saludos ;)
La escala del Trumpeter es 1:200, la del Amati es 1:250. Anímate por el Trumpeter. Pero también tienes que considerar tu experiencia en modelismo. Para mi fue la primera vez armando un modelo cualquiera y fui aprendiendo sobre la marcha.
Realmente es una construcción increíble, ¡bien hecho! Tengo una pregunta (para usted y cualquier otra persona que tenga inout)... ¿qué hace con el aparejo para asegurarse de que se mantiene firme y no se hunde con el tiempo, la temperatura y el entorno? ¿Alguien tiene un consejo?
Que tal. El rigging realmente ha sido una pesadilla para mi. Inicialmente no tengo mucha experiencia en modelismo así que no sabia que usar. Primero usé un hilo de coser de material sintético pero se afloja o se pone rígido de acuerdo a la humedad, yo vivo en Campeche, México donde la mayor parte del año hay una humedad alta de tal manera que el rigging se aflojaba y se veía muy mal y en otras ocasiones se ponia muy tenso al grado de "doblar" los mástiles (los que contiene el kit).
Ahora que volví a armar el modelo usando el Kit Pontos, para el rigging usé un hilo de coser 100% poliester y ha funcionado de maravilla. En este momento hay una humedad aproximada del 75 % y el rigging esta "intacto"
Hola a todos nuevamente. Después de un año volví a armar el modelo, esta vez usando el kit Pontos y las cubiertas de Scaledecks. Cambié el color de la chimeneas a uno mas "real" ya que siempre use un tono naranja brillante y esta vez use Tamiya Flat flesh XF15. También use un tono café para los mástiles (siempre usaba el mismo tono naranja de las chimeneas). Para el rigging usé un hilo de bordado 100 % poliéster en tono negro que no se ve afectado por humedad y temperatura ambientales.
También usé un Barniz semigloss clear Tamiya X35 para darle un mejor acabado (les recuerdo que no tengo mucha experiencia en modelismo y no sabia como usarlos). Agregué unos detalles de "oxido" con unos pigmentos de Vallejo 73.117 Oxido
Para la hélice central use la de 3 palas que según las investigaciones era la que tenia el Titanic (no la de 4 palas) y las pinté en dorado y le di un "envejecido" con un pigmento negro de Ronnin que también usé para darle unas "manchas" al casco debajo de la línea de flotación.
Agradezco de antemano a todos por sus comentarios.IMG_20230319_130254189_HDR.jpgIMG_20230319_130307245_HDR.jpgIMG_20230319_130445723_HDR.jpgIMG_20230319_130459473_HDR.jpgIMG_20230319_130546556_HDR.jpgIMG_20230319_130555797_HDR.jpgIMG_20230319_130558811_HDR.jpgIMG_20230319_130610433_HDR.jpgIMG_20230319_130613560_HDR.jpgIMG_20230319_130627628_HDR.jpgIMG_20230319_130638654_HDR.jpgIMG_20230319_130643030_HDR.jpgIMG_20230319_130658738_HDR.jpgIMG_20230319_130705352_HDR.jpgIMG_20230319_130708378_HDR.jpgIMG_20230319_130720126_HDR.jpgIMG_20230319_130727226_HDR.jpgIMG_20230319_130735361_HDR.jpgIMG_20230319_130817801_HDR.jpgIMG_20230319_130820926_HDR.jpgIMG_20230319_130830052_HDR.jpgIMG_20230319_130846993_HDR.jpgIMG_20230319_130907992_HDR.jpgIMG_20230319_130915214_HDR.jpgIMG_20230319_130926055_HDR.jpg
Si el primero quedó magnífico, el segundo con el kit de mejora quedó soberbio. Sin duda me decantaré por éste de Trumpeter.
Antes del servicio militar construí algunas maquetas de buques de la segunda guerra mundial. Espero que cuando llegue el momento se me dé bien, sobre todo con los fotograbados.
Muchas gracias por los consejos.
If the first one was magnificent, the second with the improvement kit was superb. I will definitely go for this one from Trumpeter.
Before my military service I built some models of ships from the second world war. I hope that when the time comes I'll be good at it, especially with photo-etched parts.
Thank you very much for the advice.
Saludos ;)
Aprovecho para hacerte algunas preguntas.
Que pinturas has usado?
Acrilicas?
Alguna imprimación antes?
Aerógrafo supongo.
Pegamento?
Pegamento para los fotograbados?
I take this opportunity to ask you a few questions.
What paints have you used?
acrylics?
Any print before?
Airbrush I guess.
Glue?
Glue for photoetches?
Saludos ;)
Saludos ;)
saludos!
Acrilicas?
Aerógrafo supongo.
Pegamento?
acrylics?
Any print before?
Airbrush I guess.
Glue?
Saludos ;)
PINTURAS TAMIYA
Negro XF1, una mezcal de rojo XF-7 y Red brown XF64 para el caso
Blanco XF2
Negro semi gloss X18 y Flat flesh XF15 para las chimeneas
Hobby color H310 para los mástiles
XF82 ocean gray yXF53 Neutral gray
Flat yellow XF3 para la línea del casco
Extra thin cement y Tamiya cement
Usas los diluyentes de tamiya
Realmente no use primer (imprimación) y todo fue por aerografo. Para los photoeches use un pegamento de contacto en gel a base de cianocrilato
Saludos!!
