A
Aussie048
Guest
There has been a bit of discussion lately on bending planks.
One of my previous builds had a buff bow. In the DVD that I purchase had a suggestion of how to bend planks and this can was the solution, It was the same size as the buff bow. You could use the same can on lesser curvef plank bending by just reducing the number of clamps in a lot of cases or get a can closer to the size of the curve. I just soaked the planking in boiling water for about half an hour
Issues I found was that no Hobby store supplied this can, but a lot of Chemists and Golf Club Pro shops do.
Problem 1 sorted as I found a chemist with the right tin can.
Problem 2 was I could not start planking until I had eaten all the lollies.
I did eventually start plank bending
With soaking the whole planks on my Connie I have found so far that just some map pins holding the wet planking on the bow block fillers is enough to bend the planks
