Currently working on the gunports, not happy with my progress, I just noticed that the Port side and Starboard side aren't mirror images as far as the openings go. My only word is "RATS!!!!"
They weren't on the real ship either. I can promise you that!Currently working on the gunports, not happy with my progress, I just noticed that the Port side and Starboard side aren't mirror images as far as the openings go. My only word is "RATS!!!!"
Excellent, that makes me feel better.They weren't on the real ship either. I can promise you that!
Good morning Jan. I don’t think I have seen a model where the port and starboard side are an exact mirror image - unless a robot has built one.Currently working on the gunports, not happy with my progress, I just noticed that the Port side and Starboard side aren't mirror images as far as the openings go. My only word is "RATS!!!!"
In retrospect I think I should have said ”Not Quite Lined Up The Same”Good morning Jan. I don’t think I have seen a model where the port and starboard side are an exact mirror image - unless a robot has built one.Cheers Grant
I think that is possible, only two out of the five have have "set" to far in. Another little fix as I plod along.Some of the gunports could perhaps be saved with a piece of sandpaper Jan, others might like a redo coin
Thank you for that piece of information. I was wondering what to use for that kind of backstop.The portside gunports look good Jan! Just a thought: I used off-cuts from the decking sheets as backing material for the gunports that need to be closed again. the decking sheets are quite pliable, so if you glue them and clamp them (firmly with biggish clamps) to the inside of the hull. they will conform to the hull shape. This is important, otherwise they will be "pressed inwards" when you glue the port lids into position on the outside.
Jan, you made my day - I had a good laugh now! I know I said earlier that the port- and starboard side gunports would not be carbon copies of one another in real life, but the 5/6 gunport configuration is probably stretching that idea somewhat!@Heinrich
I just noticed I have five gunports cutout on one side and six on the other. Now comes the question go with six or fill in one and go with five.![]()
One of the classic SOS posts of all times. Thank you, Jan.@Heinrich
Honestly Jan, I'd leave it just for the story you will get to tell (and show)!Jan, you made my day - I had a good laugh now! I know I said earlier that the port- and starboard side gunports would not be carbon copies of one another in real life, but the 5/6 gunport configuration is probably stretching that idea somewhat!
On the other hand, your five-gunport idea might just be visionary ... check out Zhdan's Mercury!
Seriously though - I would go with whatever option is easier for you. If filling in the gunports is easier, go with five; if cutting out an extra one is easier, go with six.
Good morning Jan. Your WB is looking awesome. I’m sorry but I had a good laugh -5/6. You certainly took @Heinrich advice literally regarding the port and starboard ports. This Does give you options tho and I hope it is not a too bigger fix. Cheers Grant@Heinrich
