in future you will not use anything else for this work
I guess a lot of sawdust and only a small number of firewood.... So no problems with what I will do in my free time in the near future.
That's right, there will be a lot of sawdust.I guess a lot of sawdust and only a small number of firewood
You have sharp eyes. That's right, I use black glue to glue the frame together. Follows how Tosti does in his instructions. Have done a test as you suggest and I like the result.In Sweden the autumn can really be dark and cold - so you will have hopefully enough time for the framing
Do I see it correct, that you use black glue or blackend glue for fixing the frame elements together? Befor you prepare all frames, I would sand and prepare one or two frames , so that you can see how the joints will look like - it is a question of tatse, if you want to have the joints accentuated or not - I think in real life the elemnents were wood against wood without any caulking or similar
ThanksNice start and beautiful wood you work with. Succes
Boy, even if glue wasn't used on the actual frames, the blackened glue really makes the elegance and tough work of assembling a frame from pieces pop without being too showy. Good call.You have sharp eyes. That's right, I use black glue to glue the frame together. Follows how Tosti does in his instructions. Have done a test as you suggest and I like the result.View attachment 392025
From this angle it looks like the coolest planter ever. Beautiful frames!Almost half of the span is glued together. It's moving forward, even if it's not going that fast.View attachment 394617
Yes, quite that big. Still, it's 1:72Impressive! She's going to be a big girl, isn't she?!?
The next step is sanding on the outside and inside, then get the right bevel on the frame. Then the thickness must be milled down to the correct measurement. I will account for all work here in this build logFrom this angle it looks like the coolest planter ever. Beautiful frames!
