ZHL Royal Caroline Kit, scale 1/30
Now these are the lanterns they give you in this, ( what others would have believe is a cheap kit with inferior wood and fittings )
I think it is a bit better than some laser cut wood that some supply,
another view,
The only thing I changed was that they wanted you to wrap the brass wire around the lanthorn base, which seemed a bit bulky
So I drilled through the base and attached the support wire that way.
I like the lanthorns a little darker, so I antiqued them a little bit.
in this pic you can see the hole in the middle that the support wire will come out from, this is also the electrical wire for the LED, positive one side negative the other
the three lanthorns
cutting the acetate to size for inside the lanthorns
the five pieces glued in place.
another view
the lanthorn lit up
John
The fitting are superb and so is the build. I am really enjoying this one
Cheers
Geoff
Leds are supplied in the kit, but they are red and I prefer the warm white ones, so I bought a set of Xmas tree lights from Cheap as Chips, was only about $5 and they came with a resistor as well.
So I cut some of the lights free, I then twisted together some brass wire to use as the supports and to supply the power to the leds,
then I melted the end of a glue stick with a candle flame and dabbed it in the lanthorn top, then pushed the leds with a spacer between them into the lanthorn top
once the glue had dried I pushed some eletrical outer cable up over the wires to act as insulation against the lanthorn body
front view, the doors have yet to be painted
Rear view
the lanthorns temporarily in plce to test that they are working OK
John
Did you need to get Alec over to wire the lanterns up.
Cheers
Geoff
G'day John
Brilliant in one word. I also prefer yellow over white. Do they blink off and on like 'a flame'? The hardware that comes with this kit is breath taking.
Havagooday tomorrow mate.
Greg
Aussie048 said:
John
Cheers
Geoff
for those wondering, the reply should be Alec who, and the answer is Alectrician.
Peglegreg said:
G'day John
Greg
Of course they do, they even have a miniature wick that you have to trim to stop them smoking
pulling your wooden leg Greg,
hey I'm a poet and don't know it,
no they are a steady light Greg and I did'nt want to get into it too much,
best regards John.
I've just spent a very enjoyable hour or so reading this log.
I've seen other build logs of ZHL kits that showed these were good quality but this log shows that that's the understatement of the year!
Things like the provision of mounting pillars, board and velvet cloth, the inclusion of LED lighting, the quality of the decorations together with the preformed masts and yards are a big step up, but the detail that really stood out for me was the provision of a set of pre-tapered planks for the cabin roof.
You're doing a great job on it.
P.S. My vote would be to remove the pins from the wales.
Zoltan was asking about the wood in the kit earlier on in the build, here is a pic,
the wood at the top is the first planking wood and the wood below is the second planking for the hull.
A little bit about the wiring for the RC, they supply a small battery box and quite a few leds, which are red, I prefer off white so I bought some from Cheap as Chips and used them for the various lights.
they say to tuck the battery box under the rear of the cabin roof, but I decided to bring the wiring up
through the hull then across under the deck to the corner of the cabin, there is a companion way that
goes in these corners and they will hide the wires, I then took the wires through the main cabin
( they will be hid under the paneling of the cabin walls ) out through the back and through to the
various points of attachment.
They give you some really nice lanthorns to go in the main cabin, but the wires are so small, I stuffed
them up, so I placed three leds along the back wall of the cabin, when the cabin roof is on you wil
l not see them.
not a very good pioc of the lights lit up.
view through the cabin front, no flash.
