ZHL Royal Caroline Kit, scale 1/30
I just checked the Casey Brass Black is available on eBay. AU$16.95 + $9.95 postage for one or $39.99 for two.
I just ran out of it myself so I have to buy - but first I am going to check it in the gun shop nearby.
Janos
This one works well if you can get it:
http://www.railroomelectronics.co.uk/Service-Aids-Tools/Service-Aids/Metal-Blackening/Product-79514.aspx
the Casey black is available at any gunsmiths stores as well. Its primarily meant for gun collectors to burnish their metal black.
G'day John
Your don't need to get me some tissues!
:greetings-clapyellow:
I've decided to get my own RC very soon. I'll be doing some major changes to the kit and it will take me a long time to redraw my plans to suit the carvings.
:D
Thanks gentlemen for giving us all the information about blackening brass.
Happymodelling everyone
:banana-dance:
Greg
Peglegreg said:
G'day John
:D
:banana-dance:
Greg
Greg,thats goingt to be an interesting project,looking foreward to it.
G'day Greg I second what Zoly said, so are they letting you buy the bits you want, or do you have to buy the complete kit, I think you will enjoy it either way,
best regards John.
G'day John
I'm buying the whole kit and that will be the foundation of my redraw as well.
Max has been great but he's working on another very interesting project. Can't say any more.
Havagooday tomorrow mate
Greg
These are the three main components for building the Companion ways
on both sides of the front of the main cabin, the two lower ones are Pear wood and the top piece is plywood
which will be planked over and then have the trim added around the top.
This shows the two companion ways glued up, in the photos they show hinges on the doors, I have not been able to find any in the kit, but there is some brass tubing and I think you have to make the hinges from this, I have to go through the videos and have a look
The port side companion way, they have to be cleaned up yet before varnishing or waxing.
The starboard side companion way
Peglegreg said:
G'day John
Greg
I think you will like it a lot, I sent him a message earlier on asking for the English instructions and parts list, most of the big stuff you can work out, but its the smaller parts, so hopefully will get them soon, have you asked for the English Instructions as well,
best regards John.
Hi John
They are very nice features to an excellent kit and build.
Cheers
Geoff
Laser cut stairs, there are 15 parts, three parts to each step,
eight of the parts have been glued together to make four of the steps and you can see two more
that have to be glued, the five dark pieces are glued onto the top of each of the steps to make
the tread
The first step in place, they are quite clever using the
moulding on the side of the copanion way to locate each step.
All the steps glued in place.
The top has been planked and the trim added around the top,
Just has to be cleaned up for varnishing.
After a coat of varnish.
Close up view.
For a change I decided to start trimming the extra wood from the
bulwarks so the capping rails and the trims could be fixed, this shows the area to be trimmed, at the
far right of the pic.
To help with the curves etc they include some wood laser cut,
see next pic.
All the wood around the carvings down to the line of the top of
the bulwarks has to be removed, so the piece in the pic can sit down on top of the mouldings.
The circles have to be cut to go around the ends of the lower moulding
After trimming away the excess wood
and the laser cut part sitting in place, a bit more sanding to do yet.
working out where the carving would go and glueing them in place
Test fitting all the carvings and port wreaths to make sure they will fit,
had to do a bit of juggling and trimming but all ok in the end, when I checked their pics they had done the same
trimming on the focsle rails
and the laser cut part in place, these are not yet glued
as they have to be sanded to match the thickness of the rails.
Thank you Janos, yes I think the western kit manufacturers have a bit of catching up to do, if they want to stay in the game,
best regards John.
The hancing piece painted and glued in place.
The rail behind the hancing piece glued in place and the hancing piece
sanded down to the thickness of the rail, also the lower drop piece is in placeThe building board
The rail assembly painted, still has to have another coat yet.
I use a toothbrush to apply the wax to the carvings,
then use a hairdryer to liquidize the wax, and then a soft toothbrush to remove the excess wax,
then when dry I use a soft nylon brush in a Dremel Rotary to buff the carving.
The carving after buffing.
And glued in place under the rail, the rail is not glued yet.
The lower rail carving has been soaked in
hot water and is clamped in position, when dry it will be cut to size, waxed and glued around the bow.
The port wreaths have been glued in position, and I am now
trimming the lower rail pieces that go between the ports
The three pieces trimmed and just sitting in place, they will
be removed and waxed, and then glued in place.
The three pieces in place and the carvings between
the ports have also been glued in place, you can see to the far right of the pic that I have
also cut to size and trimmed the forward lower rail, this will be waxed and glued in place in the next couple days.
Thank you Zoly, my plan was to do the transom and then go down along one side, learning as I go, so if by chance I make any mistakes, I can learn from them and hopefully not repeat them on the other side, so far things have been going well, and I put much of that down to the way the kit has been designed and manufactured, but as I have already said, I do not think this one is for beginners, but for sure it is a Dream to build,
Thank you for your visit,
best regards John.
