That's a really good price for all that. I have one on order too. Looks like very nice stuff.
Instead of using an airbrush with a .2 or .3 needle try one with a .5 or use a mini spray gun with a .8 or 1mm needleI have the 1/200 Bismarck also and painted the hull same way... I used Tamiya sprays... hand air brushing not an option for that surface area imo
I used TS-33 for anti-fowling as previously mentioned for all my hulls!
Looking good. I'm at this stage, more or less, and I'm wondering what white primer you used, and what white paint will be used. I've had nothing but trouble trying to use Tamiya white, but good luck with all other colors. Thanks, DaveSecond round with the hull finishing... realigned the anti-fowling line but still not positive on its location. Followed as best the paint guide and other images on the net.
Applied white primer on the top section to be covered in the middle with flat black next and a yellow pinstripe down the side next.View attachment 134901View attachment 134902View attachment 134903View attachment 134904
I have that set, and G48 is there, but is mostly a big square hole. The part is maybe 1/32 in wide around the perimeter of this hole. DaveHi Jeff,
I trust you are keeping well.
Today I received the Pontos detail set for the 1/200 Titanic and noticed when checking all the brass-photo etched frets, that part no: G48 which goes around the fore deck hatch was missing.
I am curious to know if it was missing from your detail set as it’s very strange when it’s clearly marked on the instructions.
Could you please let me know.
Thanks,
Beau
Hull painted the bottom section anti-fowling... used Tamiya Fine Surface primer in Oxide Red and then Tamiya Dull Red TS33 which is what I use for all anti-fowling on all my ship builds so far it is the closest match I can find in a spray can. I cannot imagine or entertain the notion to hand airbrush a model of that scale!View attachment 134687
I think this looks spectacular. I too used the oxide primer but didn’t apply any top coat. Exceptionally done!Hull painted the bottom section anti-fowling... used Tamiya Fine Surface primer in Oxide Red and then Tamiya Dull Red TS33 which is what I use for all anti-fowling on all my ship builds so far it is the closest match I can find in a spray can. I cannot imagine or entertain the notion to hand airbrush a model of that scale!View attachment 134687
