as a CAD draftsman i have to be able to create drawings that are workable and to do that i need to understand how the laser software sees my drawing.
top left is a line simple the laser knows to go from point A to point B
next is a series of lines i can create that with lines or polylines and then edit the polylines into one object
next is a spline and like the above poly lines the spline will used the points and create a smooth curve
to the right
a simple arc cad will create and arc from the 3 points
next a polyline and below it is a polyline that has been edited, you can see the same points where CAD used those point and created a smooth curving line. other programs may or may not see the editing the same as CAD
doing a detailed drawing it may take all the above types of lines to produce the object. You can see in the little bud the amount of points.  In a final drawing there could be hundreds of these points.
Does a laser start and stop at every point?
zooming in on that bud which is only a small part of the drawing and you can see how many point there are. The overall drawing of the vine can have a couple hundred points how does this affect a laser if at all.
I have done drawings and sent them off to a laser cutter and they told me the sheer amount of data is choking the laser, it can not deal with that amount of points
We have a number of CAD people here on the forum so knowing how to do a drawing that can be cut is a good thing to know
