Hi Heinrich,Hello Everyone
In my previous post I mentioned that the bulwark bracing has to go in next. To help explain that I used the following photograph:
The idea now is to glue 2mm x 3mm strips (indicated by the blue arrows) on top of the waterway and against the inner sides of the wales to act as bracing and as a start for finishing off the interior part of the wales. I say "start" because these slats will have a horizontal 4mm plank glued on top of them with more vertical bracing on top of that. Finally, the whole assembly will be finished off with another horizontal plank on top of that. Finally the sides will be painted black on the inside.
So the whole process was started. On the drawings these slates are supposed to be installed approximately 5mm apart, but I stretched the distance to 1 cm in case I decide to place the cannons here. 5mm would just have been too close for that.
Port side completed.
This picture indicates the horizontal plank laid on top of the bracing slats (in red) and the horizontal plank (in green) that gets placed just below that.
And without any coloured lines to spoil the picture, that is what it looks like at this stage. The starboard side was also done and then it was time for some deck planking and finishing.
This picture shows the start of construction of the half deck wall with door sills in place. As the windows are not covered and one is able to see through them quite easily, the area behind the wall had to receive attention. Left as it is, it would give an unfinished look so I made the following plan:
A piece of bamboo sheeting was cut to size, folded and inserted into the area behind where the half deck wall would go. No more unsightly areas ...
The finished half deck wall. I am still going to mount handles for the doors but am looking for the right sized rings. Everything I could find until now is simply too big.
The finished (except for the waterways) half deck with wall in place. Behind the half deck, the planked poop deck is also visible.
Close-up of the planked spar or helmsman deck.
The following pictures show the sequence of assembly of the wall for this deck.
Half-assembled - the overlapping planks can clearly be seen.
Assembled, before trimming.
Trimmed. Ready to be sanded and painted.
Wall in place on the spar deck (second wall from the front). The poop deck (furthermost to the rear) has also been planked.
And then work on the forecastle started. Note the mildew that has formed on the MDF due to the extreme humidity during summer on the East Coast in China.
Grating installed in forecastle. Kolderstok's plans for the Batavia do not indicate ant grating - just a closed hatch. As I will be making use of closed hatched on the deck area, I wanted something different here built the grating according to the exact size of the hatch.
And this is where we are at close of business today.
Just to make sure that everything is still straight and true ...
Thank you all for watching and for following. As always your comments and input are greatly appreciated.
Stay safe, keep healthy and take care.
Warm greetings - Heinrich
An American builder noticed me about the word foil - this is normally used for thin metal sheet. In the new manual I am writing I will replace the word "foil" for "cleer plastic sheet".The "foil" treatment
