Lookin Good Kurt
Why look at drawings if you can check the real thing, thats the great advantage of building Vasa.Hey Everyone, I'm looking for some help.
I am preparing to lay out and cut gun port openings in the primary hull. I looked ahead in the instructions and found this image.
Notice how the openings are vertically oriented and do not flow with the wales. This seemed off to me so I looked at some drawings I found on one of the Vasa Museum forums and if I am seeing things correctly the gun ports track with the curvature of the wales and are not set to a true vertical.
As far as I can tell DeAg has drawn the gun port openings parallel to the frames which is correct - but I don't think the frames ran vertical. I found the following and it would appear that the frames (yes, I realize the DaAg frames are not the same as found on the real ship) actually 'tip' along the length of the ship. See the following:
Am I completely lost here? If so, where have I gone off the rails?
And more importantly, if I am correct and I need to reorient the gun ports - how do I lay them out?
Thank you Uwe. You may not be an expert but it turns out you are correct. As confirmed by Maarten the gun ports follow the line of the decking on the inside of the ship. I'm a landlubber so it never occurred to me that the gun deck would follow a curve longitudinally along the length of the ship. Thank you for your insight!It seems, that the frames of the Vasa were really also following the deck-curve (and not rectangle on the keel)
-> this would mean, that the gunports are every time rectangle to the deck and with this also rectangle to the wales
View attachment 183946 View attachment 183948
also interesting sketches
akg-images - Search Result
www.akg-images.de
but I am absolutely not an expert on the Vasa...... sorry
Agreed Daniel. Not pleasing to the eye is what caught my attention when studying the picture from the instructions...Hi Doc,
For my 2cents the gun ports being radial or normal to the wale lines looks more pleasing to my eye. Simply running a small 90 deg square along the wales should be close enough.
Brilliant Maarten! The 3D model is just too much fun! BTW someone posted that a new improved version is coming soon.Why look at drawings if you can check the real thing, thats the great advantage of building Vasa.
See here a full 3d foto rendering of the real thing.
Vasa Ship - 3D model by Virtualsweden
Vasa (or Wasa) is a retired Swedish warship built between 1626 and 1628. The ship foundered after sailing about 1,300 m (1,400 yd) into its maiden voyage on 10 August 1628. This is a partial 3d model made with photogrammetry. - Vasa Ship - 3D model by Virtualswedensketchfab.com
Vasa was build shell first, this means the frame sections were only fitted to the hull planks and were not build as individual frames. Therefore frames are not always vertically placed and as frames form the sides of the the gunports the dont need to be vertical. The top and bottom of the gunport follow the curvature of the deck, which is at Vasa nearly identical to the wales. The gunport being nearly square.
See below a picture of the inside of the upper gundeck at the most aft gunport, it follows the deck and is square.
Want to walk around the deck, see the 3d model below. You can actually walk around if you have a set of VR glasses.
Vasa, the upper gun deck - Download Free 3D model by SWEDISH NATIONAL MUSEUMS, MTF (@maritima)
Vasa is a Swedish warship built between 1626 and 1628. The ship foundered after sailing about 1,300 m (1,400 yd) into its maiden voyage on 10 August 1628. The model is made from 11500 photographs taken with a dslr camera and a ringflash. Since all parts of Vasa are covered with polyetylene...sketchfab.com
Hope it helps.
i will enjoy following the build !!The kit comes in 12 (monthly) boxes and each box contains the individually packaged stages that correspond to the build steps (detailed in the Assembly Guide on the Model-Space website).
The first thing I did was open the boxes and take a complete inventory. Did I have all the packages? It appeared that I did (oddly, one was labeled for the German market but that surely shouldn’t matter).
I then identified all of the cast metal/decorative pieces and removed them from the packages. To the extent that I could I tried to combine ‘like’ pieces into zip lock bags labeling each bag with the box it came from along with the build-stage. Inexplicably, for example, the lions’ heads for the gun port covers were found in more than ten different stages of the build...
While the Assembly Guide calls for simultaneous construction and painting this seems wonky to me (though it would spread out the meticulous painting obligation). I could not imagine building the false keel and frame elements over the course of months while also painting decorations along the way. It seemed better to gather all the pieces and build the ship in the same general flow as all the other builds I have seen on the forums.
As a novice I might regret this decision since it means I will not be following the DeAg build instructions precisely. Since my Roter Lowe instructions were in Italian 35 years ago and I only speak English I felt (foolishly?) emboldened to use the instructions as a guide rather than as dogma.
About half-way through the sorting I began to better appreciate the scope of what I was going to be attempting – there are lots and lots of parts – and there are lots and lots of metal bits – and lots of the metal bits are really tiny. How was I going to detail/paint something I could barely see? I held one of the little metal guys under a 1.5 magnifying lamp. Brighter! But still tiny. Maybe I need to start dialing back my expectations!
So, that's the story of my prep work... Next post will happen when I have something to show. Thanks for checking out this new forum!
