Looking great, Daniel! That's some bluff bow. How did you bend planks?Hi all
This week has been slow for the hobby, but nevertheless I was able to accomplish some work.
First I glued some beans (see pictures with arrows) for an internal section of the lower deck. Then I added a couple more planks to the hull and finished the internal lower deck sections. Today I sanded and gave the hull a pass of Tung Oil.
Still I need to continue with the hull planking (externally and internally)
View attachment 192727View attachment 192728View attachment 192729View attachment 192730View attachment 192731View attachment 192732
Cheers
Daniel
You are making good progress. I think what @Heinrich is trying to say is glue of any kind does not adhere to tung oil very well
Okiedokie.![]()
The bond looks good! That is great. Maybe I should try Weldbond at some stage! Keep us posted; if the Weldbond does the trick, it is certainly worth using when deciding on a Tung oil finish.
Lovely work Daniel, look forward to your interior build.
Looking great, Daniel! Beautiful lines.Well, I was able to finish the main part of the hull planking. I will consider this phase finished. I will move on now to the hull interior, where the real fun is on this kit.
At this point, nothing is left of what was provided with the kit, beside the decorations and deck beams.
As I mentioned previously, I didn't use the kit planks.
View attachment 193531View attachment 193532View attachment 193533View attachment 193534View attachment 193535View attachment 193536
Cheers
Daniel
Looks good Daniel, Well done.
Do you intend to stick to the plans of the interior or have you other ideas in mind. Lots of scope to
do whatever you want I guess.
If you need inside pictures of the Utrecht let me know. I have been sailing for a day with her two years ago so I do have inside pictures of the cabins.Thank you Maarten !!! I can't stop thinking in that interior design and how to do it and where will be my skills limits.
Next will be to finish the lower deck floor and place the lateral beans support for the upper deck floor.
The circular staircase is not done by most of the modelers. That will be the first interior part I will focus on. If I fail, I will move on without that stair. And that change the beans design in that area and the cabin design too. That's why I will try that circular staircase first.
You can see that staircase in the pictures at the left of the Utrech Plan drawing.
Wish me luck..... a lot of fun... and just a very few @#$%![]()
JA JA JA
Daniel
Wishing you luck..... a lot of fun... and just a very few @#$% !!!!Wish me luck..... a lot of fun... and just a very few @#$%
