Meanwhile, I am getting ready for the internal structure components assembly, This will include various styles of doors. The kit provided doors look plain and simple. I made a decision to make my own, from scratch. Doors will require hinges, ...so I made some as the test.
The material is brass, strip, and tubing. The upper hinge strip is 0.9mm, and 1.00mm tube, The bottom (smaller hinge) is 0.7mm for both strip and tubing.
All pieces were soldered using the butane torch and soldering silver paste. The holes are 0.25mm drilled using the boxwood jig and mill. This setup works great, I use the same drill bit for all the holes. They are not in-line for now, I have to master this. But as POC ( Proof Of Concept) it is pretty acceptable.
...so, let it be!!!
...so, let it be!!!
