La Venus - French frigate from 1782 - scale 1:96 [COMPLETED BUILD]
I started building artillery on this frigate. The first idea was to make a silicone rubber mold and pour a two-component resin into it, but it takes too long for each gun. So I decided to make them in lead alloy which has a very low melting temperature.
I made the two masters in brass:
In the meantime, I started building the carts for the 18-pound guns:
Very good work and progress - you are a fast builder, fast and accurate Thumbsup
BTW: "shroud holders" are called with correct term "channels"
Very good video - I was surprised, that you have such a heavy amboss / anvil -> somehow I expected also a small one - like your La Venus.
Which type of blackening fluid are you using? And how long did you left it in the fluid?
