I can already smell that fresh Kolderstok wood. My friend, this is a special occasion and one where you will have to endure me. I will be there for the whole ride and I will share everything I know. First tip - GLUE!
AAAHHHH!!!! Now we are talking!I can already smell that fresh Kolderstok wood. My friend, this is a special occasion and one where you will have to endure me. I will be there for the whole ride and I will share everything I know. First tip - GLUE!
Try your best to get this - just make sure it is D2 . The glue must NOT be waterproof.
Robust is the word - welcome to "Blood and Thunder Building"! Stanley knife/box cutter will do the trick after repeated cuts. Take your time - and cut from both sides. As far as sanding goes - only sand smooth the little nibs where parts were attached to the wooden sheeting. Do not touch the char - it will be of great help during the fairing of the bulkheads to show you the developing hull line.![]()
That method is certainly worth a try.Hi Jan
This is what I meant by 90-degree L-shaped aluminum clamps mounted perpendicular and two-two opposite each other with just enough of a gap for the keel to slide into.
It costs nothing and with 3 or 4 of those in place, the keel won't budge. (Please excuse the very roughly-drawn illustration).
