**VIEW THREAD HERE** |
Hello Reggie, Golly but you are moving along very fast in your build, that sure looks like a very nice kit to build, will have to look into it when my Oliver Cromwell and my up coming Bluenose is finished. Yes I also per the polly on your decks. Nice job you are doing on your deck planks with your simulated tree nails.
Regards Lawrence
Hi Reggie, Just letting you know that you have someone else sitting in the background following your build. Your presenting a nice and interesting log of your RC build and it’s well worth dropping in from time to time to see your progress. Although I probably won’t be commenting a lot, just know that I’m here following.
I've got a 'deja vu' feeling. I built Royal Caroline, starting from the Panart kit quite a few years ago. (I did not use anything from the kit but the bulkheads). Now the bulkheads of this ZHL kit and the way they are built together are looking exactly the same as those of the Panart kit. Would this just be a coincidence?
János
Hi Reggie, I hope you don't mind but I'm going to join the viewing party. I have admired several RC builds at 1:30 but I fear they are beyond me - I wasn't aware of this 1:50 kit so I will watch with great interest. I won't be tackling anything new in the near future as I am neck-deep in my current project - but a man can dream!
You raise an interesting point: my decision to build a ship like the Vasa... In retrospect, as you will learn as you work your way through my build log, that may not have been my best option. But she truly is a beauty - and if I'm going to spend so much time on something it might as well be a ship I truly like. The fact that the mother ship has been raised and I can access the research surrounding her just makes it all the more fun. Anyway, this is YOUR build log so I'll stop talking about myself - I'm super excited to track with your build and encourage you along the way!Welcome and thanks for dropping in @dockattner. I am just now discovering your Vasa build and admire your decision to dive into that project. That is one beautiful ship. Am really looking forward to reading through your posts and pick up bits of learning along the way. Keep safe Paul.
I like the red!View attachment 207354
Gluing the roof of the fore castle at this time might have been a mistake. I realized I will have to paint/oil the inside wall, including the bulwarks at a later time. The roof will make this task just a bit more difficult.
I did as much of the deck planking as I could, leaving the area around the bulwarks for later since these will still have to be trimmed later ( after the hull planking is done).
As mentioned before, I am using the four butt shift planking system.
I thought I'd add a bit of color to the deck, decided to sand the front wall of the gallery (originally finished with poly) and tried a reddish/magenta paint finish. This will later on be adorned with gold resin carvings and I thought it will look a bit more exciting with a red background.
Next up will be planking the hull. But first, I faired the bulkheads to provide better grip for the planking strips.
Also, before sealing the hull, I just had to make sure the wiring for my lights is squared away. I had a lot of leftover 5mm yellow LEDs and resistors from my previous build so I used them here. I also have a 9volt battery/switch module. Based on my calculations, I needed a 330ohm resistor for each light which I soldered to the positive lead of the light. The lights are wired in parallel, positives to positives and negatives to negatives. That was a lot of soldering, so I experimented by lumping 2- 3 LEDs hooked up to a 330ohm resistor, and voila, they lit up with barely a noticeable reduction in their brightness. This saved me quite a bit of time. By the way, I also used a thin 0.25mm insulated/enameled copper wire for all my wiring. This was really so easy to use and I didn't have to worry about the wires crossing each other and causing a short.
One final test for the lights before I start planking. The 3 LEDs hanging loose on the stern are meant for the lanterns later on.
That's it for now. It's been a breeze putting this kit together so far.
Thanks for dropping by.
Great progress in assembly, the deck planking looks awesome. Will you put additional treenails as depicted in the shown image (red arrows)
Very good decision - and if you make additional treenails, I would make two nails - it is much more realistic like the Mondfeld pattern shown by Jim (sorry Jim)Thanks for the observation @Jimsky ..I initially was not planning to add them, but you are right, and after considering that in real life the planks are 20-25 feet long, I do need to put in additional treenails in between the butt joints. Appreciate the comment.
Here it is a photo showing a beautiful deck sample, and I think it is a photo Jim posted also once
Thanks, Uwe! This is from my test samples. I use hornbeam timber for the deck planking.Very good decision - and if you make additional treenails, I would make two nails - it is much more realistic like the Mondfeld pattern shown by Jim (sorry Jim)
