First of all:I could not resist to take the ship out of the jig. Gosh, it felt jolly good to see the lines outside the jigI managed to take it out without damaging the jig too much so it could be put back again. However, I decided to plank the lower part of the stern so at last the jig went into the trash bin.
The lowest planks are not sanded yet as the glue is not dry.
Now I have a lot of questions to my SoS friends
1) I assume the empty space between the 2 upper and lower deck clamps inside the ship should be planked. However, I don't see anything about it in the manual (maybe I can't see the forest for trees). Should this plank be made from scratch or . . .?
2) Also I don't find any numbers or reference in the manual to the small brass rings and eyelets on the hatches for the small decks in the hold (maybe also here I can't see the forest for trees). Are these supposed to be made from scratch? (the eyelets seem to much smaller than the eyelets on the hatches on the weather deck)
3) According to figure 19 in manual 2 the cargo hold pillars have to be installed before the platform. I think I have to it the other way around. It says pillars but the drawing shows only one. Is there more than 1 pillar? It is not on the plan and the drawing in the manual does not show the details. I know there should be some notches on the corners but I don't know the purpose of these, how many corners, how long they should be, which directions etc. Does any of you have any knowledge or information about this
4) The bottom of my frame 37 is covering the rabbet on the stern post. I don't understand why as I think it is in the right position? Looking at the plans it seems the lowest part of this frame is not visible at all. Strange! I guess it has to be modified so that it fades out into the rabbet?
5) According to the manual the sides of the ship should be planked before the transom / upper part of the stern. Is there any good reason for that or would it perhaps be wiser to do the transom first?
to 1) I saw Etiennes model also - it is a solution and maybe we should close the gap - I will see with my model, when it comes to the final installation of the interior, how it is looking likeMany thanks, guys, for the comments, the likes and the way too excessive praise
I expected already before I started that lot of questions would appear along the way. That is exactly why I found it important to attend a group build for my first build. I really appreciate that I can follow other, even experienced, builders and that we can have small 'brain stormings' when in doubt about different details.
@Uwe: Yes I did try making caulking with silk paper.
1) I think I'll make a scratch plank from the pump room to the stern like in Etienne's model:
2) Yes, we can use the eyelets from bag 07 but then they will be same size as the eyelets on the weather deck.
3) Thanks for the good picture. Helps me a lot. Speaking about climbing up and down, was there also no ladder neither in the sleeping compartments at the bow or in the galley? And could they close a 120 x 120 cm hatch from below
4) I'm pleased to know that it looked the same way for you and OT1138. It was just to be 100% sure that I had not made some kind of a mistake with frame 37
5) The reason I was asking is because it seems that the side counter timber should be rounded slightly more inwards around the lowest transom. This of course must be done before planking the side and I thought it might be easier to hit the corrects shape in both sides if the transom was fixed
There are never stupid questions - maybe only stupid answers are possible (speech of my father)One more stupid question from the ignorant landlubber then: I assume the captain's cabin was in starboard side aft and I imagine that lower ranking sailors in the 18th century were not in general obese butterballs but still . . . would the sailors sleeping in the foremast room really have to climb through a 40x40 cm window in the middle of the night to take the dogwatch? or is there another entrance somewhere I have missed?
Sorry - now I understand your question 100% !I see that hatch Uwe but isn't there a bulkhead between the hatch and the foremast room?
The better one - is the one you like most! There is no such thing as appropriate, it is appropriate if it is up to your acceptance level. I don't suggest you to made all decks in Cherry. Beech sticks would be OK, but they will not be uniform (they all from different timber thought). The best option probably is to source somewhere lighter wood for lover decks, and save maple for upper deck\s.Which option do you think is the better one?
you wrote:I have slowly started on some of interior and once again I'm in doubt: If I understand correctly the lower decks are supposed to be planked with maple. A glance at Tom's build substantiate my assumption. But there is only 2 lists of maple in the kit. Just enough for the deck in the foremast / sail room and the galley but certainly not enough for the big deck in the stern, the pump room and the magazine. I see some different options but I would very much like to hear the opinion of you guys before i make up my mind. The options I see:
1) I could make all the decks of cherry. However, using the same type of wood for everything would maybe make the interior a little 'colorless' or 'monotonous' (in lack of a better word)
2) I could make the 2 fore decks in maple and the other decks in cherry. But I have no clue if that would be appropriate? Also maybe it would look a little peculiar.
3) I don't think lists of maple are readily available in DK but I could buy some lists in abachi and make the lower decks in that.
4) I could make all the lower decks from ice cream sticks (beech I think )
5) I could make all the lower decks from wooden coffee/tea stirring sticks (birch I think)
Which option do you think is the better one? Any kind of comments or other options are welcome
Ring\eye bolts looking very good, Poul! I also have the same round nose pliers, they do allow me to make smaller ring bolts. However, making the rings using the pliers isn't practical and time-consuming, A much better way, IMHO, is to wind the wire around the drill bit or any steel round mandrel then cut with a jewelers saw or cut off the disk in a rotary tool. I have a tutorial on making a ring boltsI bought a round nose plier and tried to make some eye-bolts and rings for the hatches in the lower decks as I want these smaller than on the hatches on the weather deck. I think I'll go for the 0.5 mm wire:
I would stain the wood with ink, first, and then mount it on the model. I would even seal the wood to avoid any leaching...I also made an experiment with black ink and must conclude that even if using the best masking tape and being extremely careful I could not avoid the ink leaching a little into the surrounding wood. Question (for the far future): Can/should the wales be stained / treated with indian ink before mounting?
