Very good results - looking very good
This one bitts are directly under the small capstan at the forecastle mounted on the gun deck - and Jean Boudriot is showing this one with the double rings.Very good results for such a scale!!! Bravo! But I do have a question: is there any reason for such an unusual 'eyebolt' assembly? I mean two ringbolts, clinched together...
I think with all the detail you are doing I would have made these working hinges.
It mostly makes sense if those double-rings used for the messenger cable thought. Live and learn!!! Many thanks, Uwe!This one bitts are directly under the small capstan at the forecastle mounted on the gun deck - and Jean Boudriot is showing this one with the double rings.
So I guess they were necessary to lead a rope - maybe for the anchor lifting process and where the messenger cable was secured
Hi SAIL AND SAIL!
You have thankfully recovered from the fatigue of your eyes while building cannons.
It is a pleasure to watch this elegant frigate being built. If it becomes a kit, it should be the first one where you can follow the manufacturing process. At the moment you can see the laser marks for the upper deck beams and the openings on the rail for the extended frames. Everything is well thought out.
It is a very nice piece of work.
Best regards
Thomas
