Hi Paul, you're off to a great start. I looked at this kit once. Remind me of the scale - it looks like 1:64 or 1:72?
**VIEW THREAD HERE** |
Looks better than OK from my seat...Finished painting the hull, it came out okay. I sanded off too much primer and had to apply another primer coat between the 3rd & 4th air brush coats. I need to get the inboard bulkheads painted and install the gun deck before 13 March. The Lt will be home on leave for 2 weeks and she needs to work on the cannons. A lot of lessons being learned in preparation for my next build.
Thank you Paul, that means a lot coming from you.Looks better than OK from my seat...
Hi Paul, This is a very good effort, you are doing better than you think. I built an M.S. kit once and found that the wood was so soft that it was difficult to get sharp neat edges or a very smooth surface, try applying cellulose sanding sealer to it, it toughens the wood up and gives a better smoother surface to paint over. Don’t try and compare your build with those made from more expensive kits using better woods, they are easier to get a good finish, just carry on as your doing, I‘m enjoying your effort and will follow your progressAnother mini kit from Crafty Sailor.
I completely agreed, id does worth the effort, Those small details an eye-catcher. You did a great job, and I can recognize parts from Russian manufacturer Master Korabel.I like the way the pump turned out....PITA to build but worth the effort.
Ken, what do you suggest as my next build?Hi Paul, This is a very good effort, you are doing better than you think. I built an M.S. kit once and found that the wood was so soft that it was difficult to get sharp neat edges or a very smooth surface, try applying cellulose sanding sealer to it, it toughens the wood up and gives a better smoother surface to paint over. Don’t try and compare your build with those made from more expensive kits using better woods, they are easier to get a good finish, just carry on as your doing, I‘m enjoying your effort and will follow your progress
Ken, your HMS Fly looks awesome. Thanks for sharing, it looks like a good next step for me.I’ve included some pics of the detailing you get with this model to give you some idea. Remember though this is only my personal choice, the build will be your model and that you must like it to want to build it.
