Hi Steef,nice work again. Can you tell us more about what kind of method you use to bend the planks in form and how you measure them out?
I have a similar machine, thought the handpiece is identical to yours. As per your recommendation, I ordered a set of spare collets to fit all possible burs. It does work great, I wish it could be a bit faster, but I have not had any issues with the current speed yet.I use this one now, and must say works perfect. Light in the hand, accurate and strong. And most important, no heavy noise. I can still hear the mice on the ceiling running.
Only 2 kinds of chucks 2.35 and 3.175 in mine configuration with the extra's. 3.0 is also possible.
but that is okay when you use only cutters in the machine. Dremel is 3.175 standard and 2.35 is standard dental.
Hello CRI-CRI, I believe the translator screw up again, not sure I understand the 'squared yard', and it's an important purpose. Can you elaborate, please?Notice that the squarred yard will continue to be used, that is
an important detail, it defines vertical and horizontal reference
