I need a link, please! Must buy those...Here's my two bits worth.........har,har........ had very good results with these,
...found them but they out of stock...I need a link, please! Must buy those...
Thanks, Don.Anyone interested here is the linkHI JIM, I GOGGLED IT AND FOUND AN EBAY SITE JUST ORDERED A SET, $22.00 INCL SHIPPING, SORRY DO NOT KNOW HOW TO GIVE LINKS. GOD BLESS STAY SAFE ALL DON
As these are carbide drills, be aware of the brittle nature covered in previous posts.Thanks, Don.Anyone interested here is the link
AK-Interactive Drill Bits (0.4mm - 1.3mm) | eBay
Find many great new & used options and get the best deals for AK-Interactive Drill Bits (0.4mm - 1.3mm) at the best online prices at eBay! Free shipping for many products!www.ebay.com
Proxxon specificWhat does it take if not dremel-like tools?
That looks great! But it appears to be out of my price range of affordability (ouch).
Andy, what are the tasks you will need to do?That looks great! But it appears to be out of my price range of affordability (ouch).
I will be drilling in very thin brass, and of course wood in regards to ship modeling--not very big stuff (as far as I can see at this point anyway).Andy, what are the tasks you will need to do?
...in regards to the ship modeling - give very broad tasks in relation to drilling. If you need to drill small holes on the deck for an eyebolt, it is one drilling task. If you need to drill holes for pintles in the rudder it is a completely different drilling task. Both tasks can be achieved with a small pin-wise or spiral push drill.I will be drilling in very thin brass, and of course wood in regards to ship modeling--not very big stuff (as far as I can see at this point anyway).
Thank you so much--I own and have used a pin-vise, and I wish I thought to use it instead of my power drill. Perhaps there would not have been a problem....in regards to the ship modeling - give very broad tasks in relation to drilling. If you need to drill small holes on the deck for an eyebolt, it is one drilling task. If you need to drill holes for pintles in the rudder it is a completely different drilling task. Both tasks can be achieved with a small pin-wise or spiral push drill.
Amazon.com: Mini Micro Spiral Hand Manual Push Drill Chuck Twist Pin Vise Bit Jewelry Tool : Tools & Home Improvement
Buy Mini Micro Spiral Hand Manual Push Drill Chuck Twist Pin Vise Bit Jewelry Tool: Drill Drivers - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Amazon.com: Pin Vise Hand Drill Bits(20PCS), Micro Mini Twist Drill Bits Set with Precision Hand Pin Vise Rotary Tools for Wood, Jewelry, Plastic etc (0.6-3.0mm): Home Improvement
Amazon.com: Pin Vise Hand Drill Bits(20PCS), Micro Mini Twist Drill Bits Set with Precision Hand Pin Vise Rotary Tools for Wood, Jewelry, Plastic etc (0.6-3.0mm): Home Improvementwww.amazon.com
However, on the gugeon\pintle you need the holes inline, this will be a bit harder to make specifically drilling in the brass. You start drilling by hand to make a nice start, they use your cordless rotary tool (you have) to continue drilling at a very small speed with not too much force until you have done.
What were the results from using the power drill? Broken bit? Too large of a hole? Both can be repaired. The resultant bore can be plugged, then a new hole re-drilled. There are solutions....Thank you so much--I own and have used a pin-vise, and I wish I thought to use it instead of my power drill. Perhaps there would not have been a problem.
Actually I used a wrong description--it's a Utool rotary tool and they (4 of them) were micro drills. I was trying to drill holes through a 0.6mm thick piece of brass (the drills can go through metal, that's why I assume I did something wrong to break them). From this forum I learned that a drill press or tool stand with my rotary tool attached to it is a better choice with less (not total) probability of breakage.What were the results from using the power drill? Broken bit? Too large of a hole? Both can be repaired. The resultant bore can be plugged, then a new hole re-drilled. There are solutions....
