The box arrived today so much excitement however I must finish Fifie first...but I will probably open the box just to have a sneaky look. Wont be any action on Bluenose for a while.
John
John
Thanxs John,Thanks Dean and Peter...and Peter I am number #037 as you thought.
When I tried to unwind the small thread it became a tangled up mess...lol. So I threw it away! Glad you knew how to deal with it!Not ACTUALLY building anything but am doing some prep work.Have pencilled numbers on all the parts and made masking tape backings for sheets likely to drop pieces in the box....Have rewound the rigging thread onto cards.It is provided in skeins so you just need another pair of hands to hold the skein while you wrap a card. We used to get wool in skeins when I was a kid and I had to hold them up to be wound into balls to knit.
Start with thisView attachment 230962
Then do this
And get this
Thread needs waxing but otherwise just pretty typical stuff....
You can buy nice linen thread here which I sometimes use but I am making a conscious decision to build Bluenose exactly as it comes out of the box as much as possible. I also have some Gutermann upholstery thread which is very fine and super strong....I do like that for mounting deadeyes.
Yes the fine ones were a bit of a challenge...they have knotted the end of the thread around the body of ther skein and the small ones were the devil to undo. I ended up "undoing" them with a pair of scissors..!!....agree it would be easier if spooled or carded but a kit from PRC is new ground to be broken. .When I tried to unwind the small thread it became a tangled up mess...lol. So I threw it away! Glad you knew how to deal with it!
Every kit I have built before, had the thread on spools, and any thread I have purchased has been on spools. So this is new to me and creates unnecessary work in my opinion!![]()
Hi John,Not ACTUALLY building anything but am doing some prep work.Have pencilled numbers on all the parts and made masking tape backings for sheets likely to drop pieces in the box....Have rewound the rigging thread onto cards.It is provided in skeins so you just need another pair of hands to hold the skein while you wrap a card. We used to get wool in skeins when I was a kid and I had to hold them up to be wound into balls to knit.
Then do this
And get this
And we are off! I have set up my chair.We have made a start,the jig needed to be screwed down to flatten it completely. Easy to remove short panel screws
Same here!And we are off! I have set up my chair.
