- Dec 16, 2016
Hello, Thanks again to all those who have shown an interest in the log.
Today’s update shows the completion of the undercarriage, the instructions show how they are attached, it looks a bit confusing but when you have the actual parts in hand it becomes very clear. When they retract they not only move upwards but they also move slightly to the rear as well, this made lining up the wheel fairings a bit tricky. The fairings were fitted earlier; there were no locating pins to get their position exact, but just placement marks, I got them about right, or so I thought. When you look at the photos you’ll see that the fitting of the fairing into the wing is so exact that even at only .5mm out it will foul as mine did. I ended up removing the fairing, then when the undercarriage was in the wing I re-fitted the fairing so that it was correctly positioned.
I’ve realised that I haven’t taken pictures of the undercarriage lowered but I’ll correct that in my next post, the fitting of the engine.
