John,Hi Peter
I am bevelling the frames before assembly but after the framing is complete will go over it as a finished hull. I am finding it much easier for me to bevel before building the frame. It might be a bit hard to see as they have been painted with clear matt.
That’s an interesting approach, and I would only point out that the bevel starts at the line of the frame on one side, and ends at the furthest edge of the opposite frame. Therefore attempting to bevel one frame side, prior to gluing to the other side, won’t result in the proper bevel angle. I hope that makes sense. If not I can draw an illustration for you.I know I am doing the frames in an unconventional way but after breaking three of the first four with arthritic hands I had to find an alternatrive to ther standard approach of build the frame, then de-char, then bevel. This approach works well for me but may not suit anyone else.
Break out the components in the normal way and write the frame number on both upper futtocks above the cutoff line. Also mark the display side (starboard)
Remove the char from the parts as far up as the breakoff point. I used a small flat diamond file to remove most followed by 240 grit paper to finish.
Concave edges are easily done with a dowel glued with sandpaper
Enlarge both the keel and keelson slots in the bottom futtock with a flat file. After filing and testing a few you can gauge the amount easily.
Test fit on the keel and on a piece of the keelson material (4mm) broken off the keelson parts sheet
Yeah I know this pic shows the piece of 4mm in the wrong hole..!
Bevel the edges as shown on the parts. I do the bulk of the material to be removed leaving the final bevelling for when the frames are all installed and it can be done with a longer sanding stick.
Clamo the upper futtocks tightly over the pattern. Make many small adjustments until the bottom futtock will sit exactly in it's position.
Apply a small amount of medium CA to the joins and push into place holding for 30 secs. Be very careful to have the outer edges aligned, especially the dis[play side. I have a small piece of oven paper under the joins to stop the CA from grabbing the pattern.
Turn the front frame you have just made over , and paint a thin coat of PVA on the section to be glued. Do the same to the rear parts which you are about to stick in place. Be very careful to keep aware of the back and front side of the two sections of the frame. You should be ending up with the upper edge bevelled on the aft part and the lower edge on the forward part.
Leave for a few minutes only and the thin worked in coat of PVA will have sealed the wood and you can add a little fresh glue to make the join.
Position the aft bottom futtock using a dummy block same thinkness as keel and getting outer edge just right. Add the other pieces again being sure to align the outer edges perfectly. Do not clamp. Doing PVA this way does noes not need it and the futtocks will most likely move.
Finished....emphasise again this is a method that works very well for me but may not suit anyone else. Vive la difference...!
Hi John,I know I am doing the frames in an unconventional way but after breaking three of the first four with arthritic hands I had to find an alternatrive to ther standard approach of build the frame, then de-char, then bevel. This approach works well for me but may not suit anyone else.
Clamp the upper futtocks tightly over the pattern. Make many small adjustments until the bottom futtock will sit exactly in it's position.
Apply a small amount of medium CA to the joins and push into place holding for 30 secs. Be very careful to have the outer edges aligned, especially the display (starboard) side. I have a small piece of oven paper under the joins to stop the CA from grabbing the pattern. These two joints only have to hold the futtocks in their correct relative positions until you apply PVA in the next step below. This join is certainly not structural.
Turn the front frame you have just made over , and paint a thin coat of PVA on the section to be glued. Work it into ther wood. Do the same to the rear parts which you are about to stick in place. Be very careful to keep aware of the back and front side of the two sections of the frame. You should be ending up with the upper edge bevelled on the aft part and the lower edge on the forward part.
Leave for a few minutes only and the thin coat of PVA will have sealed the wood and you can add a little fresh glue to make the join.
Position the aft bottom futtock using a dummy block same thinkness as keel and getting outer edge just right. Add the other pieces again being sure to align the outer edges perfectly. Do not clamp. Doing PVA this way does noes not need it and the futtocks will most likely move. The join made this way is super strong.
