Sergal Cutty Sark scale 1:78 Robertd [COMPLETED BUILD]
Я тоже буду рад сесть рядом с вами и посмотреть, как строится эта красивая модель.Кофе
Made an jig and dry fit the keel and Bulkheads and sub deck , nothing glued so far , I will add the top deck as well for a dry fit before glueing , the laser items supplied by Sergal is superb , just a bit of sanding to get rid of the ‘Charcoal’ and the bulkheads slide into position , if all fits into place , I didn’t find it necessary to check all the alignments
DE874DEB-29D5-4752-AE6E-9A0F8E5619ED.jpegE310AF1C-F845-44C1-B2C4-097DF6D73AE5.jpegB79E8C96-0B71-40B5-B65D-DDDF786BBE7C.jpegE052E2A4-AF25-4EEA-A0A4-8570CFB47BAC.jpeg7FEE1524-372E-411A-A385-024D087E9D10.jpeg
Glued the bulkheads , sub deck and main deck in position ( using Gorilla wood Glue and clamps) , modified an Artesania hull clamp , I never used it as I found it too flimsy, so inserted stronger wing nuts , washers and bolts and attached it on my Dremel Vise ,actually you can use all sorts of vises , but here it shows how it is done in my yard , before installing the upper decks aft and focsl’e I intend to give the deck a clear varnish , slightly tinted as per the real CS, no tree nails.
CD94BC5A-15EB-44CA-BE0C-AF7D9C2E6382.jpeg18868FC5-118B-42E0-B299-AD2A9A45EA2D.jpeg16FCBD21-4AE9-468D-AF10-FEB3BB23DEE2.jpeg47CCABB3-D586-4864-805B-87D0B55C0BEA.jpeg
Great model I have started the same model, I guess I should start a build log as well. You will enjoy building it
Will be watching your build with interest, as I will be trying the same build in the near future. A great looking lady to model. I will hopefully learn much from you!!
Thanks Coasty , this is the easy part , next will be planking the Hull, The plans are a bit confusing but I noticed the extensions of the Bulkheads have to be removed at a later stage to deck level hence the planking only attached with clamps , so not glued on the planking at all , just glue the planking together I suppose , I also noticed there are frames (37) attached to the bullwark instead , anyway see how we go , I varnished the deck today, as parts of the deck are not accessible later on ,the extra strip # 27 to be attached to the deck first before attaching # 37 and after the Bulkheads extensions have been removed
You are flying along Robert! You are making great progress and all seems well.
Саша сказал по-русски, что будет рад присесть рядом с Дином и всем остальным, наблюдая, как ваша симпатичная модель будет продвигаться в журнале сборки.
Спасибо, Дима. Я пользуюсь Яндекс переводчиком. Но похоже, что он как то не так переводит мои слова: eek:
