Please translateЯ тоже буду рад сесть рядом с вами и посмотреть, как строится эта красивая модель.Кофе
Sasha said in Russian that he will be happy to seat near Dean and all, watching as your nice model will advance in a build log.Please translate
Thank youSasha said in Russian that he will be happy to seat near Dean and all, watching as your nice model will advance in a build log.
Will be watching your build with interest, as I will be trying the same build in the near future. A great looking lady to model. I will hopefully learn much from you!!
Glued the bulkheads , sub deck and main deck in position ( using Gorilla wood Glue and clamps) , modified an Artesania hull clamp , I never used it as I found it too flimsy, so inserted stronger wing nuts , washers and bolts and attached it on my Dremel Vise ,actually you can use all sorts of vises , but here it shows how it is done in my yard , before installing the upper decks aft and focsl’e I intend to give the deck a clear varnish , slightly tinted as per the real CS, no tree nails.
Thanks Coasty , this is the easy part , next will be planking the Hull, The plans are a bit confusing but I noticed the extensions of the Bulkheads have to be removed at a later stage to deck level hence the planking only attached with clamps , so not glued on the planking at all , just glue the planking together I suppose , I also noticed there are frames (37) attached to the bullwark instead , anyway see how we go , I varnished the deck today, as parts of the deck are not accessible later on ,the extra strip # 27 to be attached to the deck first before attaching # 37 and after the Bulkheads extensions have been removedWill be watching your build with interest, as I will be trying the same build in the near future. A great looking lady to model. I will hopefully learn much from you!!
Looking forward how you are getting along tooGreat model I have started the same model, I guess I should start a build log as well. You will enjoy building it
Спасибо, Дима. Я пользуюсь Яндекс переводчиком. Но похоже, что он как то не так переводит мои слова: eek:Саша сказал по-русски, что будет рад присесть рядом с Дином и всем остальным, наблюдая, как ваша симпатичная модель будет продвигаться в журнале сборки.
