Also keep in mind that resin usually requires a primer coat prior to painting, or the paint will chip off easily. You can however carefully hit it with some steel wool to help with adhesion, prior to paint. If it is molded, then the release agent has to be cleaned off with soap and water using a toothbrush or equivalent.i fully understand scale and printing from the gothic steam enging i am designing. Most of the detail was to small for 1:48 scale so i am doing the diorama of the engine room in 1:32 scale which will allow more detail. An advantage to working from your own original CAD design allows you to tweak various areas or parts as apposed to using an existing design and just scaling it.
As for printing i will go with a resin printer so larger scale and a finer resin printer is at about the best you can do. Lucky there are thousands of resin printing services so that will be no problem
Plastic will take paint well without any primer. Also resin requires using CA to be glued. A few more differences worth noting.
safety tip - resin is highly toxic when inhaled...so always wear a mask when sanding.
