US Frigate Essex - 1:50 [COMPLETED BUILD]
I guess this is a self made tumbler, or?
electric drill driven, I guess
How long does the blocks need in the tumbler until the edges are round?
and: do you add some additional material inside, or only the blocks?
Thank you Dave.
Yes Uwe, I made that simple tool which is electric drill driven to sand the small parts. 2 minutes is enough for the wood I use but perhaps the time may change depending on the kind of wood. And no I don't add any additional material inside but the inner surface of the drum is also covered with sandpaper.
Very good work with your boat and the hammock support frames - very accurate work
Will you add also some nets for storing the hammocks?
