- Sep 28, 2020
Beautiful!
Beautiful work. Well done.
have no more superlative to give you, more than I have all your image in safe. Only ONE question. Do You want these little rough images of many Wooden Parts. I would sand it and then sealed it. As it can de see there are scares and then Hundred if Not thousand Tiny hole. Thise tiny home are ideal for Bacterial grows- Just a question
will come back with some comments-el capiThe main rail, lower rail and cathead supports have been completed. View attachment 230634View attachment 230635View attachment 230636View attachment 230637View attachment 230638View attachment 230639View attachment 230640View attachment 230641View attachment 230642View attachment 230643
THE ONLY WAY TO DO IT.It is the same if you have Open Gunports. better do it, before closing the decks.Great progress, Mustafa!! I like the idea of leaving the thread to pool the actual anchor rope later!!![]()
I don't have a proper rope right now. When I get it I will use those threads to pull the actual anchor ropes up to the gundeck.THE ONLY WAY TO DO IT.It is the same if you have Open Gunports. better do it, before closing the decks.
iI have finished working on the head for now. I made and installed the grating, seats and the other details.View attachment 230979View attachment 230980View attachment 230981View attachment 230982View attachment 230983
agree with you Uwe.Very good progress - with very good result
I have only one suggestion - maybe are the diameter of the "holes" of the four seats of ease slightly too small - it will be hard to strike home
see f.e. the seats of ease on the HMS Victory
Seats of ease
Looking for some information on what on my Rattlesnake plans call "seats of ease". I do know what they are....ahem....used for, but on the plans all I see is a circle. I'd like to put some detail into this feature if in fact they are something more than just a round thingy to sit on while...shipsofscale.com
Uwe, in fact I didn't know the diameter of the holes in full size. I drilled with a 2 mm of drill bit and the scale is 1:50Very good progress - with very good result
Seats of ease
Such wonderfully clean work. She is a real beauty for the eye to behold. I'm learning a lot sir.The main rail, lower rail and cathead supports have been completed. View attachment 230634View attachment 230635View attachment 230636View attachment 230637View attachment 230638View attachment 230639View attachment 230640View attachment 230641View attachment 230642View attachment 230643
