Well, it may not look like much, but this is the result of 3 days' work...
WELL DONE, MATEWell, the water-based stains I was waiting on came in, so work has resumed. While I was waiting on them, I spent my time working on another project, a nixie-tube clock I’ve been building for the last year someday I may even finish it lol.
I finished with the second layer hull planking a few days ago. Not terribly pleased with how it turned out, but I learned a few things that I’ll be able to apply next time. Also, the top section on the bulwarks turned out much better, since I was able to use copious amounts of clamps.
After the stains arrived, I was able to get the plates at the bow installed and have started putting the bumper rails on. I’m going very slowly with this, gluing down a short section at a time and clamping it so it has ample time to set before moving on.
View attachment 241778View attachment 241779
Getting excited to start working on the deck furniture!
You can always sand it flush with the keel if you want.Had some time last night, so I tackled installing the rudder/tiller. Started by drilling a hole with a Dremel. I then took a round file, and marked the point on the shaft with tape where my calipers showed it was 7mm in diameter. I carefully worked that into a slot 15mm long by 7mm wide, as called for in the plans. From there, it was just a matter of positioning it so that I could attach the small brass straps to the hull to hold it in place.
The bottom ended up a little lower than the keel when I was done, but I kind of like the way that looks. It makes it a little distinct from the keel and sternpost.
s and the deadeyes for the bottoms of the shrouds came next:
Building from Kits does not mean, that each piece fit totally. To lower the manufacturing cost -like metal parts -are being produced to more the one model,Many Kit builders just goes along with instruction manual -GENERALLY WITH MANY MISTAKES - and do not use comment senceAfter looking at the post from @El Capi I decided that making my own pieces was probably the best course, so I took some more of the scrap laser cut frame and sketched out a couple of yokes (I’m guessing that’s what these are called, please correct me if I’m wrong).
I grabbed the ol Dremel and in a few minutes, I had the rough cuts. I used some small files to refine the shape and round the edges, and I think they look ok for a first try.
They certainly fit the mast much better than the metal ones that came with the kit.
View attachment 245991View attachment 246000
With that, the masts are built and ready for installation. Excited to get to the rigging!
What you have done here are absolutely 1Th Class.After looking at the post from @El Capi I decided that making my own pieces was probably the best course, so I took some more of the scrap laser cut frame and sketched out a couple of yokes (I’m guessing that’s what these are called, please correct me if I’m wrong).
Morning. Doing good work. The only little thing I have to comment. Te DEADEYES shall/ will have to be Paralelsa. The aft pair is not. Good workWell, the masts are mounted, and I believe all the standing rigging is on. Tomorrow I will start on the running rigging. I worked a good deal of the day on this, so I anticipate that during weekdays, when I have less free time, it will take me a few days to get it finished. I anticipate that I may be able to finish this build next weekend!
Here's a few shots of the day’s work:
My first deadeyes! Went better than I expected. Feeling good, moved on to the second:
Not bad. Wait, something seems a little… off?
NNNOOOOOO! I got the shrouds twisted around each other! Well, no way to fix it except cut the deadeyes apart and do it again. I paid a lot closer attention after that.
Shrouds, stays and bowsprit all done. Whew! Think that’s it for today.
Thanks for the kind words, Paul. I know since I have been on this forum, I've gone to look at some builds that look really fantastic, and then for some reason just vanish (sailed into the Bermuda Triangle perhaps? lol). I feel like the bug has bitten me with this. I'm really having to force myself to take a break to do other things, as I said.Congratulations Mark! You are in rare air - you finished a kit! Many builds get started but it seems they eventually languish...
And your Polaris turned out great as well. Bravo!
Great job! Congrats!I was able to finish up last night.
Here she is:
I have to say, I'm pretty pleased with how it turned out overall. Are there some flaws? Yes. Things I would have done differently? Yes. All this information and knowledge will just make my next one that much better. I'm already looking around for the next one, and I've narrowed it down to a couple of options. I do think that I will take a bit of time before I begin the next build, though. I jumped right into this with several projects left undone. Need to play catch-up on those items before moving forward.
A few notes on my impressions of this kit. I chose it in large part based on it being one of the kits @Donnie mentioned in a post about good kits for beginners, and I have to say, I think it was right on the money. It's not an expensive kit, so if it turns out model ship aren't for you, the investment to find that out is modest. I have certainly spent more on other hobbies before figuring out I didn't want to continue. But, for that small investment, I feel like I got a little taste of most of the basics of model ship building. Double planking, mast making, wire shaping, and just enough rigging to challenge an absolute beginner like me. The instructions and plans were pretty easy to understand and follow, and this is one of the models for which OcCre has a complete playlist on YouTube showing each step, so if something isn't clear in the drawings, you can refer to the video, which has been helpful.
There are a couple of issues, as have been documented here. The planking method is not what the experienced builders would recommend, as I learned, and I will make the effort to employ more efficient methods in the future. Also, the metal yokes for the spars are not at all sized properly for the diameter of the masts. I would say if you are planning to build this kit, ditch those right from the start and just make your own from scrap wood.
So, that's my 2 cents. I've really enjoyed this experience, and thanks to all who have given encouragement and advice.
Thanks,
Mark
