and poly????For the ropes, to gets points of authenticity, they have to be made from natural fibres such as manila hemp, hemp, coir, jute, and sisal.![]()
...yep, G'uterman brand.and poly????
I was using for "tarring" mixture of beeswax, paraffin, turpentine and wood tar, like pine or birch.Indeed it is Vic. But look at Matt's result:My goodness! That seems like a lot of work for so little gain.
Hey Matt ( @mati.n ),Hi Paul,
I was away from forum for a while so I've just now noticed your ropes posts and dilemmas.
Your ropes looks really good. nice and tight twist.
Color is always personal taste of each individual modeler and how it will look at the model.
True... we all try to match "real look" of the ropes, but using cotton, hemp, silk, poly threads it will always create challenge at the beginning.
...but sooner or later modeler, will find the method, which suit his taste
I was experimenting with many threads.
Each has advantages and disadvantages.
I went for poly... mainly because cotton and other natural material threads are bit problematic if you want to achieve nice and smooth finish... and not like hairy caterpillarI was using for "tarring" mixture of beeswax, paraffin, turpentine and wood tar, like pine or birch.
Cotton has also seasonal disadvantage in my climate where at home during winter we have dry air due to heating and ropes are nicely stretched and during spring and summer where humidity is higher cotton ropes are getting bit saggy
Poly threads has also plenty problems... but at least they are not loosing tension due to seasons.
Rope made of regular poly threads also looks like hairy caterpillar so I was using hot air gun (like for soldering) to deal with that to smooth it out. However, after tarring it was necessary to repeat hot air gun process to get rid of unwanted "hairs" from rope.
Poly threads has also problem with "electrostatic field" which obviously will for a dust like a magnet... so to break it a bit, we can used highly diluted shellac in pure alcohol. Shellac is natural isolator... however shellac will make ropes bit stiffer.
Then I switched myself completely to poliester silk threads (silk is just a name, and doesn't have nothing common with real silk).
I didn't have Mara threads in my hand, but looking at the photos they looks to me as just a regular poly threads.
Poly silk thread from Gutermann, which I know and I have is called Skala (in my case I have Skala 240...)
Other brands for example Serafil or Synton from Amman... not sure, what you can get in US... but if you will get thread for leather-working you will know how they look. Poly silk has a bit more shine than regular poly threads but after tarring in bitumen is not so obvious.... and that's bring us to tarring, which is a bit challenge for poly threads. Coloring them to achieve proper and durable effect, which won't rub it off it might be a problem.
Of course you can use some dye or stains... (wood based won't work so it has to be alcohol based) but I found my durable, friendly and easy method with bitumen.
You got yours from Pentart, which is ok... not as good as Idea Decoupage Liquid Bitumen No 741 by Maimeri , which I'm using... but I guess in US is not available. As you mentioned for standing rigging I'm not diluting bitumen, just taking some on top of the brush and dabbing rope in the jar from each side to cover it fully. Then I'm wiping off excess, leaving the rope for few minutes to dry... and finally when dry... I'm taking cloth damp with white spirit making few passes to remove excess of bitumen but still keep fair amount in the groves (white spirit - regular and cheap from hardware store not the one for artistic use, isopropyl alcohol works fine as well)
For running rigging I'm diluting bitumen with fair amount of white spirit. Then soaking twice whole rope in the jar, wiping off excess, drying and once again few passes thru soaked cloth.
I'm using only white or off-white threads, sometimes beige.
For ropes up to 1mm I'm usisng thread no 360, 250, 240, 120...
For thicker ropes I'm oing to 80, 60 40...
If you will need some help let me know, we will try to do it right
Cheers,
Matt
Hmm. I have not tried the bitumen treatment on the lines colored with oil paint. I stopped at the burnt umber coloration (diluted in linseed oil in my case which is the carrier for the pigment in the first place) which did turn out very nice but monochromatic. I'm on holiday. When I return home I'll give that a try.liked and agree everything Matt said ... actually my experience says the same to me , at least I've passed same stages as Matt did))...
and stopped on GUTERMANN TERA or for best results Poly silk thread Skala ...
colors preferable need to be white or slightly colored... actually it doesn't matter which color they are(but only must not be red or green!)), later they will be painted in necess-ry color anyway...
Strange to hear that method of coloring them by mix of tick oil deluted in whitespirit and artistic oil paint didn't work ... did You use all mentioned components ?and apply mix as advised?
This should work the same way as Matt advised to use and apply bitumen liquid on the rope, the only difference in colors which You will get in the end.
Using bitumen alone You will get only variation of brownish colors, from dark to bright...as on Matti model...
But using / adding artistic oil paints , Umbra and Gold Ochre to this mix, I think we could add them strait to the bitumen diluted with whitespirit, We will get more natural hemp colors for running rigging and more intensive, dark -for standing rigging.
Which exactly colors we will get purely depends on master own test, but at least it should be very close to natural hemp colors, but not too much white as we often could see on many models.- I understood very bright color for rigging if it should imitate modern synthetic rope , but it looks very strange on period ship models![]()
Vic, who said it will be easy???My goodness! That seems like a lot of work for so little gain.
Hello, Paul. I have obtained Maimeri bitumen patina 710 thru the Russian store.I have contacted Maimeri but I believe that will go nowhere. I agree with @Jimsky - the Pentart color is a bit unappealing - but it may be all I can get.
Fantastic Kirill! I look forward to reading more about the construction of this fascinating ship! Thank you for sharing this find with me and the forum.Good day Paul,
Found recently...I didn't read it yet, but could be interesting!
The author compares the hull construction of the Vasa with Witsen's standard work.
Part of the work is the creation of a very detailed 3D model.
Lots of pictures.
http://oaktrust.library.tamu.edu/handle/1969.1/153363
Very intricate. How many of these pieces are there to paint?Hello Fellow Modelers,
One of the interesting aspects of this Vasa build is the ample opportunity for artistic expression in the area of painting (painting ridiculously small metal bits that is). Before the research completed at the Vasa museum about ten years ago it was universally accepted that the many wooden carvings on the ship were gilded and models were naturally presented that way. In recent years some (many?) have attempted to replicate what we now know to be true: the carvings on the Vasa were multichromatic. This introduces a new challenge to the modeler...and to THIS modeler in particular. Not only am I new to model ship building - but I am new to painting miniatures of any kind. The learning curve is a steep one in both regards.
Here, with humility, I present two postings that show what I have been working on in recent weeks (along with my rope making experiments).
First of all I'll show two parts that form the most forward decoration and the most aft decoration on the ship: the lion at the front and the lions (and crest) at the back:
As you can see I have chosen to flatten the gold. As far as I can tell from my research these parts were not gilded - so I have chosen to present them as painted in a gold color.
Next up are a series of Roman soldiers that will appear on the underside of the lower of the paired galleries.
The last image only shows one of a pair - I simply took the photo wrong.
In the next posting the art exhibit will continue (I learned I can only include a limited number of photos in a single post...).
