OK MORE PROGRESS DRY FITTING DECK BEAMS AND HORIZANTAL SUPPORTS BOW AND STERN, THIS WAS ONE MASSIVE BLUNDER UNTIL I GOT IT RIGHT IT WILL TAKE TO LONG TO GO OVER THE WHOLE PROBLEM IT STARTED WITH BEAM CLAMPS THERE IS A SHORTER ONE AND A LONGER PIECE I DID NOT RELIZE THAT IT MADE A DIFFERENCE WITCH WAS TO THE BOW AND WITCH TO THE STERN, WRONG, WRONG I HAD THE SHORTER ONE GOING TO THE BOW LONGER TO THE STERN IT SHOULD HAVE BEEN REVERSED NOW IF YOU LOOK AT PICTURE YOU WILL SEE WHY THE HORIZANTAL SUPPORTS AND THE BEAM CLAMPS MUST REPEAT MUST BE IN LINE SO THERE WAS THE PROBLEM SIMPLIFIED HERE IS THE CORRECTIONS ALSO I HAVE TO PUT THE BEAMS ON THE HORIZANTALS AND THEN GLUE THE WHOLE THING IN PLACE BUT THAT IS NOT THE END YET MORE TO BE CONTINUED. GOD BLESS STAY SAFE YOU AND YOURS DON
