Yes and at an older age we are not embarrassed or shamed in doing so unlike the overconfidence of youth. RichWe do whatever we need to do Rich!
|  | As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering. |  |
 ask me how I know
   ask me how I know  , or maybe you don't want to know.
 At this point, this looks like an impossible task to find the space to rig them like that.(even though I would dearly like to). Hmmmm ...
 At this point, this looks like an impossible task to find the space to rig them like that.(even though I would dearly like to). Hmmmm ...An interesting factor to ponder with these pounders is that at that size they were around 5,000 lbs static not to mention the kinetic energy of the recoil. Hard to use the prys to work the breech ends for any angle firing which then would require an angled tackle arrangement. Smoke, noise, splinters flying and blood everywhere. All luck of the moment if the gun crews survived or not. And then having to right the gun carrages that were blown onto their sides and tangled in the tackle. Glad to have not been aboard although your model is enticing when the action is disregarded. Nicely done. Rich (PT-2)Hello Everyone. On to cannon-rigging.
The drawing.
In theory, this is how a 36-pounder Dutch cannon of the 17th century was rigged. I obtained this picture from Modelbouwforum on one of the many builds of the Zeven Provincien, but I have no idea from which build anymore! So I do apologize sincerely to the artist.
And in practice this is what they looks like mounted on Arjen Spiek's majestic Zeven Provincien. This picture is particularly helpful as I will also have three cannons per side with the lifeboat in the middle.
BUT ... the Haarlem's deck is considerably narrower than that of the Zeven Provincien!At this point, this looks like an impossible task to find the space to rig them like that.(even though I would dearly like to). Hmmmm ...
 The picture is an example of what SHOULD be done - and - just like you have so aptly described the chaos of a naval battle on deck, so I am dreading it to find the space to fit everything that needs to be fitted. In the Haarlem's case it's not only the conventional rigging that is a nightmare to me - it's also the rigging of the cannons. Those blocks are miniscule!
 The picture is an example of what SHOULD be done - and - just like you have so aptly described the chaos of a naval battle on deck, so I am dreading it to find the space to fit everything that needs to be fitted. In the Haarlem's case it's not only the conventional rigging that is a nightmare to me - it's also the rigging of the cannons. Those blocks are miniscule!You may able to "Shanghi" a smaller crew for those mini tasks@PT-2 Hi Rich. Noooo ... I haven't done anything.The picture is an example of what SHOULD be done - and - just like you have so aptly described the chaos of a naval battle on deck, so I am dreading it to find the space to fit everything that needs to be fitted. In the Haarlem's case it's not only the conventional rigging that is a nightmare to me - it's also the rigging of the cannons. Those blocks are miniscule!
 Rich
 RichHappy crew aboard!!!The Admiral to the rescue! ... hopefully ...
 rich
  rich
Hi Heinrich,Hello Everyone. On to cannon-rigging.
The drawing.
I have no idea. I just found it in my search. maybe English.I have a question for you about the last color picture that you posted. Is that picture from a Dutch ship?
 A glutton for punishment ...or ... plain stupid? !
For the reason of "limited space", I would leave off the lines in the back. As mentioned, those were used to pull it back to do initial loading.@dockattner Hi Paul. It is great to see you back here and your input is much appreciated. Now what makes matters worse for me is that the Batavia which obviously is the base for the build did not have any cannons on the exposed deck. So, yours truly is trying to fit something into a space for which it was never intended.A glutton for punishment ...or ... plain stupid? !
