The bitts came out really nice.
Nice deck planking seams following the scraping. Sharp razors remove the whiskers so when I ordered more I got 100 so that I can change them often. Your work is progressing well. Rich (PT-2)I found that darkening all sides of the thin plank strips with black Sharpie marker causes the ink to bleed into the ends of the plank, and the lines to be too dark and coarse. That was noticeable on my last ship. To reduce that effect, four things were changed. The marker used was switched from black to brown, only one long edge was darkened, the ends were not darkened, and the deck was scraped smooth with a razor scraper. This deck may not be as smooth as decks to follow, because of access limitations, but it's smoother than leaving it unscraped like on my last model. The port side looks a little lighter in color, but I hope it will age and darken to match the rest of the deck.
The deck planking for the lower gun deck is finished, except for the waterway strip on the port side, which I need to get more 1.5 x 1.5 mm strip to complete. Did ships this early have a spirketting plank above the waterway?
The deck was coated with Krylon Satin spray lacquer. It adds a small amount of shine without making the wood look like it was dipped in glass, which looks terrible in my opinion.
CRAP. I forgot to do the midplank trenails again.
I'll get them later.
These enhancements take SO MUCH TIME - but they will add up and will result in a fine model of this ship (though I suspect these will be hard to see unless you intend to leave some decking off (?).Knees sanded and stained. The lower knees made of basswood look better than the upper pinewood ones.
Know what REALLY took time? You making all those freaking little dots on your Wasa!These enhancements take SO MUCH TIME - but they will add up and will result in a fine model of this ship (though I suspect these will be hard to see unless you intend to leave some decking off (?).
Very, very well done all due to your shaping of the razor to the cutting profile. That is a skill within itself!!! Rich (PT-2)I ordered some etched 1.5mm eyebolts from Radimir at HiS (Historic Ships) in Czech Rebublic and are waiting for them so the cannons breach ropes can be made. So, in the meantime, columns or pillars were fabricated for the lower gun deck. Since shipping Caldercraft column parts from UK is so expensive, they were made from scratch. I took a trick from Shelk, who made the finest weathered Santisima Trinidad I have ever seen, and created a cutter from a razor blade in mere minutes using the cutting wheel on the Dremel tool. To keep the spinning piece firm while shaping, sections of 3/16" hardwood dowel were cut on the bandsaw and placed in the chuck of the tabletop drill press. The drill press was set to maximum speed. The razor blade cutter was clamped in a machine vise and pressed carefully into the side of the spinning dowel. Sometimes, as the part diameter approached 3mm at the top end, the piece simply broke off. But, the part is still usable. Each pillar was also spun in a hand drill while pinching a green Scotchbrite scrubbing pad around the spinning part, polishing the wood. Then they were all stained with dark walnut Danish Oil.
The whole process took only a couple hours, faster than I thought. Also, the pillars cost mere pennies. Later, each pillar will be cut to length and installed as the beams above the lower gun deck are fitted.
an interesting way to turn the wood. Given that I know you have a lathe, may I ask why the drill press was chosen as apposite to a lathe? Is there any specific reason?To keep the spinning piece firm while shaping, sections of 3/16" hardwood dowel were cut on the bandsaw and placed in the chuck of the tabletop drill press. The drill press was set to maximum speed. The razor blade cutter was clamped in a machine vise and pressed carefully into the side of the spinning dowel. Sometimes, as the part diameter approached 3mm at the top end, the piece simply broke off. But, the part is still usable.
Hmm....more control? The cutter should go slightly above the centerline of the wood. If the 'tool' is not firm against the wood piece, you risk getting hurt, IMHO. Horizontally you have more control, don't you think?@Jimsky I think, because I would do the same, more control. You can drag the clamp over the table of the drill stand
Before Kurt will elaborate... Here are the few basicsYes you have to be in control and be careful. Looking out what Kurt would say.
