Hi PaulThe rigging is finished!! Finally! I'm now working on attaching the flags (as you can see I've attached the first one on the foremast) that I got from hismodel.com (see the last picture in this post). I've purchased a lot of stuff from him - he never disappoints. On the lower picture you can see the flags that are drying after I've soaked them in GAC 400 - it stiffness natural fabrics and fibers.
View attachment 257171View attachment 257172View attachment 257173View attachment 257174View attachment 257175View attachment 257176View attachment 257177View attachment 257178
Paul, any recommendations on where to get the lanterns?All of the flags have been installed. I've also finished the stern ornaments and the stern lanterns. The lanterns are 3-D printed that I purchased somewhere on the web and look very nice – much better than the supplied one's. I simulated the glass by using Microscale Micro Kristal Klear. Next up will be the 4 anchors, then the rope coils around the belaying pins.View attachment 257731View attachment 257732View attachment 257733
I found the vendor I used:Paul, any recommendations on where to get the lanterns?
Yes they are.Are the flags printed on both sides?
Thanks so much, Paul!Yes they are.
Hi PaulAll of the flags have been installed. I've also finished the stern ornaments and the stern lanterns. The lanterns are 3-D printed that I purchased somewhere on the web and look very nice – much better than the supplied one's. I simulated the glass by using Microscale Micro Kristal Klear. Next up will be the 4 anchors, then the rope coils around the belaying pins.View attachment 257731View attachment 257732View attachment 257733
I suggest you check out my website build log:I'm currently working on the SR stern gallery. Any hints to make things easier? I'm a little intimidated. I've got the frame work in, now contemplating the best way to do the curvature for the very upper supports.
Lines every which way but loose!I am now working on the rope coils that hang from the belaying pins. Following are pictures describing how I make them up.
View attachment 258611View attachment 258612View attachment 258613View attachment 258614View attachment 258616View attachment 258615
Hi PaulI am now working on the rope coils that hang from the belaying pins. Following are pictures describing how I make them up.
I purchased my blocks from Syren - I too found the ZHL blocks lacking. I'm sure that the blocks from HIS would be very nice.Hi Paul
Very nice indeed.
By the way, did you use the blocks that were included in the kit by ZHL or did you use other blocks?
I find the quality of the ZHL blocks rather limited and consider getting those sold by HIS Model.
I'd appreciate your view here.
Thanks PaulI purchased my blocks from Syren - I too found the ZHL blocks lacking. I'm sure that the blocks from HIS would be very nice.
Maybe you should consider also the blocks by @Dry-Dock Models & PartsHi Paul
Very nice indeed.
drydockmodelsandparts.com
