I'm glad you got your book and plans. Now it's time to start making some dust and perhaps start your own build log. Regarding this log, I intend to report progress as soon as there is progress or questions, assuming I don't croke or get kicked out of SoS. Good luck with your build.I now have plans and will be starting this modle my first. Hope to follow your build. Do you plan to keep up with the build log?
Daniel,Gennaro, the book you linked come with all the plans/drawings you need to built the ship ?
I am asking because I am not sure if Sea Watch books, with this comment ( ....The framing is based on volume one of the Fully Framed Model ( the Swan series) and this book will be a big help for anyone tackling this project....) is suggesting that you need the Volume 1 too
Thanks !!!
Daniel
Regarding mill and chisels, nothing fancy here - 12 years old Proxxon MF70 and xacto 1/4" square blades for rounding corners. The rest is done with scrapers, files, sanding sticks... Learning curve is really not that sharp. It took several attempts for the lower apron, but I managed to manufacture stern deadwood and rising wood in one go. Light is also a very good helper for inspecting joints and shapes (shadows). All the work is done very slowly in multiple passes. As David Antscherl said multiple times, it's a lot easier to remove the wood than to put it back on. Thanks for your interest.Gennaro, what kind of mill and chisels do you use? How would you describe the learning curve to produce such precise parts? Awesome project and awesome skill! I am hoping to use Ed Tosti’s Niaid books as reference for my CAF Granado and Enterprise builds, but hope to eventually scratch build.
Thank you Adi. Much appreciated. I'm glad Hoy is not clinkered framed/planked. I don't know how you guys are handling Le Coureur's framing/planking.Hallo Gennaro, your project is just fantastic, great work. I will continue to watch you with great interest, as I also have book and plans, maybe?
Well there I have a lot of other tasks.
I haven't made any frames yet. All frames are double sided except for the one at dead flat. So the double frames are 20" full size at floors.Could tell me what thickness you made the frames on Hoy? I have a problem with the plan, floor are to be 10" is that the final double frame or is the final 20"?
Ok thank you. I will be watching when you start to make frames. I will start on the keel just like you did almost done with my build board.I haven't made any frames yet. All frames are double sided except for the one at dead flat. So the double frames are 20" full size at floors.
Yes if I can figure out how to do it properly.Macbass, are you going to do a build log? Could be an awesome tool/help for some one else,plus we get to see your progress…
You will be surprised how easy to start a build log. It is a matter of 'post a thread' in the section below. Just give it a title and...Yes if I can figure out how to do it properly.
