Hallo everybody, few days ago I received the Alert kit from Trident Models. Everything went quickly and without any problems. I'd like to thank the administrators UweK, Zoly99sask and Jimsky for their help in ordering procedure, and of course Trident Model for the beautifull kit. I plan to build the model with the help of the instruction manual, AotS by Peter Goodwin on Alert and what is very important: the detailed build logs of the Alert Group Bild community. This is going to be my first build log on this forum.
I started with the keel, placing all the parts into the keel template after cleaning. Everything fitted well together and could be glued. I also sanded the cuts for the metal parts already at this stage of construction (they were a bit tight) which is easier than later with the frames attached.
I had a first look at the berth/construction jig/space ship and after some slight sanding started to glue it together. I did not glue nr.15 into the berth.
That's it for the moment. To be continued soon.
Greetings
PeterM
Greetings
PeterM
