La Couronne Corel/scratch 1:100 First build [COMPLETED BUILD]
Ramsey, Minnesota, USA
Hello everyone!
Like my father before me, I sailed merchant ships as an Engineering Officer, and have always loved square riggers. After eight years living aboard ship, seawater still flows in my veins twenty-five years later. I built several plastic ones as a boy, and now am returning to the hobby decades later, this time with experience in medieval weapon and armour smithing, carpentry, machining and other trade skills. A decision had to be made as to which era of sailing ship to choose.
The 17th century royal great ships peaked my interest because of their embellishment and style, set apart from the advanced, refined warships of the Lord Admiral Nelson's time. So, the first ship, what I consider my training vessel, is La Couronne c. 1636. It's an ambitious ship for a novice such as myself. EJ's La Couronne build on the Nautical Research Guild was an inspiration, and his build log serves me well as a guide, since plans alone are not sufficient for a first time project. I also purchased Deagostini's Sovereign of the Seas, all packages, and am saving that for building closer to retirement in 10-13 years. The challenge of the small scale of 1:100 of La Couronne is rather high, trying to include the level of detail I desire, plus the addition of either full or battle sails. Silkspan is the material that is planned to used for the sails. I hope I don't tear them to ribbons in the process! A ship isn't complete without sails, no matter that they block some of the view of the deck equipment.
Special note: Thanks to our administrator Donnie for help in construction of this build log. The log originally started half way through construction, and the beginning steps were added over a year after the ship was finished. The posts for those steps were inserted at the beginning of the log, starting with the one below, in order to present the build steps in chronological order. Some of the dates for the posts may not be correct as a result, but now the build log is complete!
3/21/18 - The build begins
Right out of the box, it was apparent that the number of guns needed to be increased to 72, but this meant a complete rearrangement of the gun ports. Another builder of this model also added more gun ports, and his drawing of where he moved them was used as guidance for where I placed the gun ports as shown below. Since I had no idea how the frames of a 17th century ship would be spaced, I left the original kit's frame locations as is and placed guns around them.
The beginning of the build started like most kit builds. The upper gun deck was left flat, and it was decided that the lower gun deck would be installed and contain full cannon carriages instead of those silly half-barrels that Paul likes so much. :D
Per the instructions, 4mm x 0.5mm tanganika strips were cut for deck planks and glued to the false deck. I was especially careful doing this because it was my first time. However, staining all four edges of each plank with a Sharpie pen turned out to create lines between planks that were too dark and thick to represent a deck on this scale of 1:100. In the next build, only one long side of each plank was thus stained, creating a more realistic appearance.
The deck is partially planked using a 5 plank shift pattern. Note the keel vise I made from ash wood in my shop. It will come in very handy later when you need to lean the masts toward you or tip the bow or stern up or down, since it is adjustable. The made the many hours of ratline tying much easier on my arms.
Planking continues. This deck was left flat. Higher decks would be altered to have proper camber.
Not too bad for as first timer. I didn't know about scraping the deck with a razor blade to make it smooth, and only lightly sanded it. So, the deck plank edges can be felt by touch. However, all the seams are tight and the planks are straight.
More planking.
Time to figure out how to make a lower gun deck. Pieces of balsa were lightly stained and glued between the frames and sticks were applied to the frames underneath each deck piece to add some support. Balsa was used only because I had it on hand and it was quick and dirty. You won't see the deck anyway since it won't be illuminated because of the presence of the center bulkhead. Here is the first piece being test fitted.
All the deck pieces are test fitted into place.
Deck planking is completed, working around the frames.
Supports are installed as the lower deck piece were glued in place, taking care to place them precisely the same distance beneath the lowest slots which were precut by Corel on the edges of the frames.
Deck piece supports.
The upper frames were stained with golden oak stain.
The deck beams, were cut with camber on the top surface per the instructions and test fitted.
To add some color, the frames where painted red by the builder's choice.
You have invested that money and time well resulting in the beautiful model that will be treasured beyond your expenses. Don't feel adrift as I have been going on the same tack of never ending purchases across a broad spectrum of everything available. . . addictive it seems. Rich (PT-2)
Being a rookie, I have not yet got into the ordering extra for my ship. However if I convert the cost per hour relative to enjoyment this has to be one of my better spends todate.
Tell me the truth, Kurt. Can you really see the difference between the half guns and the whole guns with carriages by looking from the outside? Show us a picture, please, of the finished product. Up close and 3 feet away. ;)
For most people, using full carriages on the lower decks is not worth the effort. It comes down to personal preference, but when Paul does it, I just call it laziness. ROTF (With his dentist-hands, he can work microscopically if he chooses and it's just fun to mess with him.) When I look at the model, it's not from across the room. I get my face right up in there and look at the detail, often banging my head against the plexiglas. And yes, from three feet away, I can see the reflection of light off the flat black wood behind a dummy barrel. It ruins the realism for me, though others usually don't notice. Oh, and I'm near sighted. :D It helps with rigging.
Now for the fun part, making tiny cannons! Below is one of the Corel supplies cannons. They throw them in every kit regardless of time period or size. However, they are pretty nice. But now that I've dispensed with the half barrels, I bought some smaller barrels to use as 9 pounders on the upper gun deck, and these barrels will be used for the 18 pounders on the lower gun deck.
New gun carriages need to be made. Since I was not familiar at the time with the assembled gun carriages available from other vendors like Dave at Ship's Lumberyard, the task was to make copies of the carriages in the same one piece style as the ones Corel provided. Taking a stick of walnut wood, a light milling machine (a 1964 Linley jig borer) was used to create a channel.
A piece of wood was similarly prepared for the smaller 6 pound saker guns used for the fore and stern chase guns.
On an old Delta 890 band saw, a stick of pine with a piece of walnut scrap glued to the side of it for a stop was used as a fence. It was simply clamped to the saw table. The wood channels were first cut to the length of their respective carriages. The depth of cut for each of the steps was carefully set by the fence, and each step was cut into the batch of carriage pieces. The band saw cut remarkably smooth and did not tear the wood. A Corel made carriage is at the bottom, being used as a model for setting the step sizes.
I made a plastic disk with a tighter slot for the blade so my saw doesn't eat parts or mangle them into bits. You can see how some of the cuts are progressing, each one with a different set up of the fence and stop.
Here is a pile of the 6 pound saker carriages next to the new 18 pound carriages. The curved channel in the center of the bottom of each carriage was hand sanded using the edge of my bench grinder. Low tech, but with steady hands, precise enough.
The bottom carriage is Corel stock. Mine came out okay.
I took a 3mm wood dowel and made it black with a Sharpie pen. After spinning a 3mm dowel at 90 degrees to the blade on the band saw, using the stop on the fence to stop short of cutting all the way through the dowel, I discovered I could make simulations of the axel ends for the smallest carriage's wheels without using real shafts. The dowel was tuned by hand against the cutting edge of the saw blade. The nibs of wood that were not cut off the discs and looked just like the ends of the axles, once separated from the dowel with a razor knife. The wheels are just glued to the sides of the carriages. Nice shortcut that yielded extra detail. You can see a the bottom of a Corel carriage with axel shafts next to a hand made carriage with wheels simply glued on.
The edges of the bulkhead frames were sanded rather easily using a small "mouse" vibrating sander with course, 60 grit paper on it. It removed wood fast in a controlled manner. A strip of linden wood from the kit is used to check the angle of the frame edges by bending it across the frames along the hull. Before sanding, the four frames nearest the bow were painted black on the edges. As the sander removed wood there, the black at the trailing edge of the frame indicated how much more wood was needed to be removed. Over sanding would change the shape of the hull and create flat spots in the hull curves.
The block of wood in the lower bow to which the plank ends will be fastened was also shaped to the three dimensional curve of the hull using the vibrating sander. The area close to the keel board was filed by hand.
The upper deck, quarterdeck, bridge deck, poop and forecastle decks were test fit after being pre-curved. Curving the decks was accomplished by soaking them for 20 minutes in warm water, then pressing them to the side of a small plastic bucket and holding them there overnight by wrapping the bucket with 1/4" rope. The next morning when they were dry, the curve remained in the plywood pieces. The instructions do not call for curving the decks, with some like the forecastle deck being flat, so this is a change made for better accuracy.
You can see the sheer curve of the decks as well as the camber.
Another view. I like how the shape is developing.
The method I chose to modify the transom was the unnecessarily difficult, but I was concerned about preserving the subtle complex curves of the provided pre-cut stern block. So instead of piecing the stern and transom together with strips of thin wood and plywood, the block was laboriously hollowed out and the gun ports separated by small blocks of wood. You can see one of the tin 6 pound sakers used to help gauge the size of the gun ports.
The pre-cut pieces of wood that form the counter below the transom were glued onto the transom block.
View of the transom block from the inside.
Transon assembly glued to the stern bulkhead frame.
Because the deck does not extend to the forward bulkhead, a piece of plywood was used to extend the deck and thus provide a place for the fore chaser guns to be placed. Scrap wood pieces were used underneath to provide more support.
When bashing a kit, you occasionally run into a necessary step which would have been much easier earlier in build. The front bulkhead was too thick, such that the fore chase gun barrels would barely protrude from the front. A chisel shaped razor knife was used to chew away enough wood to thin the bulkhead. It isn't pretty, since access was very limited, but it works.
Now the gun protrudes the proper distance from the bulkhead. The sill and edges of the portals were painted red.
Corel provided portal lids, but they did not have the rebated edges, so thin plywood veneer was cut into squares and was glued to all of them to add detail.
Like the front end of the upper gun deck, the rear end did not reach the end of the hull. A piece of veneer plywood was on hand and used to extend the deck. Strips of wood were glued to this extension to provide the shape of the camber.
It's not very strong, but it doesn't have to be. It's purpose is t o serve as a place to mount the rearmost cannon carriages.
Strips of tanganyika wood stained on the edges with a Sharpie pen were glued to the beakhead deck.
Strips of walnut were likewise blackened on their edges and glued to the forecastle forward bulkhead.
Small blocks will be used to simulate the traversing blocks and quoins.
The first hull plank is attached using glue and 7mm thin pins from Amati. The plank is run under the lower gun deck gun ports. One of the most clever features about some Corel kits is those small slots cut into the frames. Those cuts mark the upper and lower edges of the gun ports for both the gun ports. The save you a lot of measuring off the drawings and reduce the possibility of errors. They also reduce trimming of the planks since the strakes of wood run right along the upper and lower edge of the line of ports. Quite clever really.
The four lower bow chasers are assembled. They are quite tiny.
The bow chasers are glued in position.
The look good from the front.
Great mass production and tool use. The results are in the viewing. Rich (PT-2)
A second set of planks is run below the upper gun deck's line of gun ports. Linden wood can bend and twist to form all the curves you need it too, especially after being soaked in water.
Planks that have to bend in sharp curves are soaked in water, then formed using and electric plank bending iron and a concave form to press the strip into. The hot iron heats the moisture in the wood on contact, forming steam that evenly heats the lignum in the cells of the wood and the strip act like plastic, holding its shape after cooling. Clamps hold the parts in alignment edge-to-edge for that part of the bow which curves down to meet the stem.
A portal was cut out for the dispatch portal. I placed a cannon here, but really it should be empty. It's that single portal you see which is not far above the waterline, below the lowest gun deck and close to the stern. This portal is sometimes a big smaller than a gun port, and is used for deliveries of small goods, dispatches (letters and correspondences) and is usually shown on a model as closed. A section of deck had to be installed here to accommodate the gun carriage.
Planking continues.
More planks added.
More planking...
The planks appear a bit lumpy but will sand out smooth later. The pins holding them in place while the glue dries are sunk into the wood enough that they don't protrude. You can optionally pull these pins after the glue dries. Sanding will remove the heads off any pins that stick out too far.
These next pictures show the progression of planking the hull. The garboard strake was laid along the keel, and the gap between the planks higher up on the hull and those at the bottom was slowly closed.
Note how the gap between the groups of planks is narrowing quickly at the bow.
The gap has closed at the bow, and you can see some of the planks come to a point, with no drop planks being used instead. A beginner's mistake. Luckily, since this is only the first layer of planking, it doesn't matter much as far as hull strength goes. On a real ship, "dagger planks" are weak spots where leaks develop and are to be avoided using proper planking patterns and techniques.
Instead of pins, I tried using office clips to hold the planks while the glue dries. It works, but pins work better.
Always plank with pairs of wood strips, port and starboard. It keeps the hull from warping, and also makes the ship symmetrical.
With the last plank covered, planking will continue up the sides of the hull.
Hull planks trimmed and sanded at the end of the transom.
Low spots are filled in with wood filler.
Filling low spots it critical in getting a smooth hull. If planks make hard bend over any of the frames, the hull could appear faceted when finished. To prevent that, filler is applied on either side of the shallow "fold" at the frame, and then sanded. The process of adding filler, sanding, and examining for flat areas or hard folds may have to be repeated three or four times before you are satisfied that the hull is smooth. Care at this stage is what makes a nice hull. Use your fingers to feel for flats or hard bends. Your hands are actually more sensitive that your eyes. Shadows you can see are often not created by fold, but appear in areas where the translucence of the filler allows the wood texture to peek through. It throughs your eyes off, making you think there are flat spots where there are none.
First sanding after filler.
Stained a bunch of cannon carriages.
Installing cannon carriages on the lower cannon deck.
After final sanding of the lower hull.
