Hi Roger. That sounds good. I have some of the thin plywood that I can use that for backing.
I'm sorry that you were close to an accident in measuring the ropes. I I will order some thinner thread, since all of what I have seems to have a lot of chuff. If I did want to use some of it, does beeswax smooth it out?I no longer have my scribbled notes on the actual sizes I used. So I tried to use my micrometer on the actual model today but after snagging the first rope that I measured I stopped. The small parts and lines are too delicate to withstand an accident, yikes!
Without actual ship measurements I originally estimated rope and wire sizes from museum photos. Lifeboat falls would have been a minimum 20mm manila (diameter). Topping lifts and guy tackle probably the same size or larger for this ship. Forestay halyard, as an example, probably 12mm. Based on those estimates if you look at a museum photo of the St. Roch you can see the aft wire on the foremast is slightly larger than the two shrouds with the rat boards. I think I used 0.3mm (actual 22mm) for the larger diameter and then a little smaller diameter for the other two. They might have been a little larger but at this scale there is not a lot of visual difference. Remember, the scaled lines you decide on must pass through the holes in blocks where relevant.
One of the enjoyable aspects of ship modelling, I find, is to research different sources for both some realism and for historical reasons. If you search for “St. Roch Vancouver images” or something similar you will find close-up photos of various parts of the ship, which will help you enormously. Don’t forget the museum staff may also be able to provide you with accurate sizes for all of the rigging presently installed, if that is important to you.
Hi Bruelves, Many thanks. Are you building the St. Roch? Maybe with my photos you can avoid some of my mistakes!!Hello Carl. This is my first venture into building a ship model - and my first look at the SOS forums. I have found the pictures in this building log astoundingly useful! Thank you.
Great...Maybe if you get ahead of me, I can rely on you.. I am making steady progress. I'm now retired and have lots of time to work on the kit. I found that the instructions on this model are very skimpy. There's no step by step manual with detailed diagrams of photos. I myself have relied heavily on other builders' experiences. You can find them on my previous posts in this log. I'll be excited to see your own progress.Hi Carl. I have started a build log for my attempt at St. Roch and will log my progress there. Your photos have already helped me enormously. I just need you to stay ahead of me so I can follow along!
No issue at all Carl, my near clumsiness and focal distance issues at the momentI'm sorry that you were close to an accident in measuring the ropes. I I will order some thinner thread, since all of what I have seems to have a lot of chuff. If I did want to use some of it, does beeswax smooth it out?
No issue at all Carl, my near clumsiness and focal distance issues at the moment![]()
I know what focal distances and clumsiness are all about.No issue at all Carl, my near clumsiness and focal distance issues at the moment![]()
I know modellers have used beeswax on their rope over the years to remove/lessen fuzz. I understood the disadvantage is dust accumulates more easily on the lines. I used the rope I purchased without the application of any other treatment. There are many modellers who use it in combination with other methods to achive a certain look. Probably the best solution is to search on this and other sites for "beeswax", you'll get many hits.I know what focal distances and clumsiness are all about.By the way, will beeswax smooth put some of the chuff on rigging thread?
Thanks Roger. My education on boat modelling continuesI know modellers have used beeswax on their rope over the years to remove/lessen fuzz. I understood the disadvantage is dust accumulates more easily on the lines. I used the rope I purchased without the application of any other treatment. There are many modellers who use it in combination with other methods to achive a certain look. Probably the best solution is to search on this and other sites for "beeswax", you'll get many hits.
Enjoy the time...grandkids and the model-building!! Cheers.I am also retired but I can only work on the kit in small bits - grandchildren to take care of. Only the diagrams in the instructions are of any use and they are skimpy too.
