Yep that is a true story. Perfect.Perfect !!!!
Daniel
The wire is bent around the double sheave.
Your “La Belle” is like her name: “The Beautiful”. That is what you made her!And the final varnish is applied.
View attachment 268612This is how "La Belle" looks in daylight.
Best regards
Thomas
Since everything is loosely mounted, a change is possible at any time.There must be some hook making school in Germany. Outstanding work Thomas!The rigging of the starboard anchor.
Rope guide for lighter anchors. . .
. . . and the implementation on the model with hooked block with double sheave for the tackle.
The guidance of the rope on the windlass.
Following pictures show the production of a double sheave with hooks, as any modeler can easily make them yourself.
5 mm double sheave from Dry-Dock Models & Parts and a piece of 0,4 mm blackened brass wire.
View attachment 269761The wire is bent around the double sheave.
The wire ends are soft soldered, bent into a hook and then filed into shape with needle files.
After chemical blackening it looks like this. Really any modeler with a little patience can recreate this.
Best regards
Thomas
C'est superbe,Bonjour!
Avec du bois supplémentaire et un peu d'expérience, vous obtenez "La belle", "La Belle".
View attachment 150364View attachment 150365View attachment 150366View attachment 150367View attachment 150368View attachment 150369View attachment 150370View attachment 150371
View attachment 150359View attachment 150360View attachment 150361View attachment 150362View attachment 150363.
Je le voulais et je l'ai eu grâce à la CAF !
Avec mes meilleures salutations
Thomas
Oh Ja - when we take a look at the metal works from @archjofo or also Thomas here - very good qualityThere must be some hook making school in Germany. Outstanding work Thomas!
The sktech shown is I think printed in Rödings book - I realized, that we can not find so much information about horizontal windlass in the web, so we have to check here printed publications ..... at it seems that you are right with the revised order of the cable around the drum (in and out above) - many Thanks for showing us this detailNow you produced a new error .. sorry for the hazzle ... cable must come in and go out from above.
The kit contained four triangular rings (above in plastic bag). But as soon as I start, I make all the rings myself. In the case of round rings, the wire is wound on a corresponding drill and cut open with the side cutter. After completion of the eye screws and rings, the openings are bent shut, soft soldered and the components blackened.
