Thank you Fiddlewood for reminding me about the rubbing strips on the hull, this is what is supplied in the kit, a half round section,
and a view of the outside of the half round strip,
according to the plans the long piece goes 14mm below the base of the bulwarks, I was lucky and had some masking tape that was 14mm wide, so i ran a strip along the hull and used it as a guide for attaching the strip, i used CA Super Glue,
close up view,
I didn't have a hole punch big enough to do it the way Fiddlewood did, so after attaching the long strip i used a drum sander to round off the end of the short downward fenders so that they would sit up against the long one,
another view,
first one attached again with super Glue,
Port side done,
I have now come up with another problem, they give you a U shaped length of rubber to go around the lower part of the bulwark,
But when it is put in place it comes up above the deck at the wash ports, the only thing I can think of is to attach and cut away the area that is where the wash ports are, or just leave it off altogether, any thoughts welcome,
  best regards john,
