- Dec 26, 2021
This starts my first build log of the ZHL Black Pearl which is the "Golden Version". I will be posting images very soon.
Thank you, oh it's certainly a challenge especially for my first build one step at a time and look way ahead so you don't have too many surprises.
Tony I'm learning how to navigate the forum, how do I access your previous build logs?If you are going to install lights (well worth the effort) and you haven't assembled the frames yet work out where the wires are going and drill the holes now it's will save you a lot of time later. Check my Black Pearl log for further details.
Hi this link should take you to my log.Tony I'm learning how to navigate the forum, how do I access your previous build logs?
Hi Rick.Hey Tony, let me tell you my story my first time i bought a BP back in November I was having back surgery the end of December I was going to need something to do. I bought BP model from Wish, it came in a plain box no label hardly had any instructions, missing parts,and so on i started building it and got frustrated, so after joining the forum i met Donnie I decided to purchase one from Max now I had a model I could build that had all the parts and plans.Did your model have black walnut 0.5×4.5×400mm that was to be used for second planking and the deck because for the deck material i would like something like 1mm. When I was playing around with the crap model I bought first I put some planking on the forward deck and it really hard to work with, it splintered a lot and really came out not very good.
While I was building this kit we where all in lockdown and the postal service was useless so I tried to use everything that was supplied in the kit, it was only after the second planking was finished I regretted using the same material on the deck.Do you know where I might be to find something that's 1mm thick ? Did you the same plank on the hull?
